Adjustable Top Mounts
    Im having Bilstein PSS10 coilovers fitted on thursday and im considering having adjustable top mounts fitted at the same time in order to get the correct camber etc.
    I was looking at the Turner Motorsport ones - BUT someone has mentioned the Nitron adjustable mounts.
    Does anyone know whether the Nitron ones are fully compatible with the PSS10's?
    Urgent advice needed!
    Members 'david' and 'TANKSLAPPER' both used to have Bilsteins fitted and presumably top mounts. They may be able to help
      there's some top mounts for sale in the for sale section and pistonheads
        I had PSS9 with Turner Motorsport top mounts (AKA Simpson) Bistein are good shocks, I changed mine after 2 years for KW club sport
        I think the rubber bushes in the turner Motorsport mounts are only good for two years on track. An excellent set up for fast road and the odd Track day.
        The PSS9 & PSS10 are easily to set up and adjust much better than the standard suspension on the road and track.
        If you are doing a lot of track days then I would look for a different make top mount.
