I have a situation, or maybe I don’t, I have just had Thorney fit new AP discs and RS29 pads across the rear, thanks John. These of course require bedding in properly, which requires reaching low medium and high speed, and the progressive…bollocks, you lot know what I mean I shall not dilate on the matter further.:hahaha: During the Dyno run, Thorney diagnosed a fooked head gasket, I discovered that this was covered under my full BMW Warranty, especially as my car is a garage queen , never having been tracked or “Rung”:whistle: ..Car is currently with Andy at Murketts, who has accepted my explanation of the roll cage as being somewhere to hang my clothes from. The situation I have is that I still need to bed the brakes in, with all this entails, the problem is do I also need to follow some obscure BMW running in procedure for a new HG? as the final stage of bedding in requires hard progressive braking from a speed of about 350 mph, down to 50mph.! Thoughts on a £20 note and send to me :thumbs:
Chicken & egg, brakes or engine ??
Finally, someone who knows what he is talking about instead of taking the p!$$, no wonder his is a Mod.A few questions so i dont fook up, 1 should I start off in launch control?, or traction off?2 what temp should the oil be at before i go out on my head gasket bedding in run? 3 do i do it at night, air more dense, or is it ok during daytime ? thanks for the advice Mark.Originally posted by mark csl View PostDuncan as with a new engine redline it in every gear to bed in the new head gaskit as the car is under warranty :whistle:did i say that out loud :hahaha:
at theend of the day Duncan youcan do both still as the HG will max require rev limits whereas brake bedding in just requires you to get up to a speed and brake - you dont have to rev the balls off it!Originally posted by DuncanR View PostBurgered if I know mate, im no CSL techno head, I shall take advice from Andy at Murketts, watching the Irish v Leinster game , it decides if Saints go thro to next round.....btw what is 30 mph ???
Yes you do Shim ... you really do !!! :hahaha::hahaha:Originally posted by shimmy View Postyou dont have to rev the balls off it!
I will sort it out proper mate, I shall put my sensible Engineering head on and find a happy balance, just need a longer straight run to build up speed without revving nuts off it !
Saints thro !! :thumbs::thumbs:
My original thoughts entirely Craig, but then I got to thinking , surely BMW are going to make it more complicated, at the very least I would have thought they want to re-check the torque on the new bolts after so many mailes or so?? just guessing.Originally posted by Craig View PostEngine up to temp, drive it how it should be driven!
Joking are you not? BMW service being efficient, yeh right.Originally posted by DuncanR View PostMy original thoughts entirely Craig, but then I got to thinking , surely BMW are going to make it more complicated, at the very least I would have thought they want to re-check the torque on the new bolts after so many mailes or so?? just guessing.
You will be fine duncan, just drive it as normal, just be patient for temp to rise before booting it,
What were your symptoms??????
Ding ding ding !! Correct!!Originally posted by Craig View PostRunning a head gasket in? All it is, is a seal thats squashed when the heads tightended!?! I can understand bedding in a freshly honed bore, but not a head gasket, if the gaskets gonna fail, its gonna fail no matter what.
And mate your dealership must be really gullible to believe your stories :hahaha:
