Porsche BREMBO 4 pots for the CSL ?
    Originally posted by mole View Post
    They seemed to work very well from where I was sitting this weekend :thumbs:
    :hahaha: :hahaha: :hahaha: even with the poor old, slightly warped, grouch CSL discs :thumbs:
    GREAT lap solutions @ the Ring & Spa Mr.Mole :beer:
      Hell Yeah :supz:
      They were a revelation :thumbs: both at the Ring & Spa, after the BMW O.E. single piston wrongness, even with slightly worpped discs, damaged previously by the before mentioned BMW O.E. wrongness :banghead:
      I'd say they are not as FANTASTIC as the AP Racing SIX pots (AlexK :supz: and others) but then again BREMBO don't make S**T brakes and these mono block Four Pots are VERY light and use larger pads with the refinement of four pistons pushing them with finesse and NO brake fade :thumbs:
      My whole objective of this BREMBO CSL project was to retain & utilise the O.E. CSL 345 mm floating discs as they are great and I don't like wasting such good stuff. :hahaha:
      Yes, you will need CSL front discs (I'm buying my NEW ones today) but the biggest obstacle is getting the correct bracket solutions as they are NOT readily available off the shelve, however I might have solutions :beer:
      Sounds really good :thumbs:what solution do you have for the brackets?
      CT
        CT
        Possible availability solutions :beer:
        p.m. me for more
          Hi,
          MattCSLnut- Nice to see all your effort has
          worked out.
          I'll expect that there is virtually little if any
          difference between your set up and AP,s
          or whatever.
          Plus you have a little less unsprung weight.
          Easy Disc replacement, off the shelf, a very
          good overall package.
          Are you going to fit a biais valve into
          the rear brake line now, so that you can
          alter the rear biais when wet etc ?
          Easy to do, route via cockpit, and then you
          can adjust to suit conditions as driving.
          Regards,
          The Gorilla.
            I can confirm that the Brembo solutions are good brake solutions !
            :thumbs:
            Besides that, they also look cool.
            Very good mod !
              i can confirm that the brembo solutions are good brake solutions !
              :thumbs:
              Very good mod !
              Thank U please :thumbs:
                Originally posted by The Gorilla View Post
                Hi,
                worked out.
                or whatever.
                Regards,
                The Gorilla.
                Hey Gorila.
                First of all a BIG THANX for all your invaluable input :thumbs: Much appreciated :beer:
                Indeed BREMBO brake solutions have worked out well for me and earlier on today I purchased a pair of shiny NEW CSL discs for £100 each + VAT from E.C.P. Made by ATE which I believe are the same maker of the ones sold through the BMW network @ £156 + VAT :whistle: Can U confirm please ?
                My only limitation that I've been made aware of is I mustn't try running very HOT pads like the Pagid RS29s with my set up as they may warp my CSL discs, which have a smaller contact surface to the larger AP racing ones. Having said that I've settled on a medium compound pad, the Pagid RS4-2 aka Pagid Blue and they seemed perfect so far + only £170 + VAT for a set. :thumbs:
                With regards to the biais valve, do I really need one ??? After 23 laps of the Ring and 16 laps of Spa this weekend, in all sorts of weather (but mainly rain :bigcry: ) I didn't feel the need for this mod.:smt017 Surely the electronic trickery of the car will sort this out itself, No ???
                  Matt the brakes look awesome and glad to hear they were up to the task. :thumbs:
                  Have you changed the rears or left them standard?
                  I can see me looking into this option in the future.
                    THANX :thumbs:
                    The rear callipers & discs are O.E. standard however pads are Performance Friction Z rated TD pads for now, Goodridge braided brake lines all round and ATE Racing Blue fluid through the veins :beer:
                    Start looking now as the bracket solutions are a bit tricky. I can get them but minimum order of 6 units (3 sets) is required by the Machine shop I use.
                      Hi,
                      MattCSLnut- A rear in line Brake bias valve will
                      increase or reduce the amount of rear Brake.
                      Most cars are around 70% front 30 % rear.
                      When you fit a Bigger Brake to the front
                      this ratio can alter to say something like
                      75% front 25% rear.
                      You would not really notice this in normal
                      driving conditions.
                      Bigger brakes do not dramatically alter the
                      brake grip or bite, but they do increase the
                      their ability to maintain the brake pressure over much
                      longer repeated periods. Much less fade
                      Come the rain though, and you would need
                      to restore the original front / rear brake ratio
                      and even increase it in really wet conditions,
                      by having more rear bias.
                      Something like 65% front 35% rear.
                      So by having the bias valve in line for the rear
                      allows you to compensate for the changes.
                      Regards,
                      The Gorilla.
                        THANX for the explanation Gorilla :thumbs:
                        Maybe I should just look into BREMBO rear brake solutions over standard rear discs :beer: or get the AP Racing rear callipers ?
                        Thank you please :whistle:
                        Hi,
                        75% front 25% rear.
                        driving conditions.
                        Regards,
                        The Gorilla.
                          Just picked up your thread and very interesting it is! I have a full set of big reds of a 996 gt3 same as turbo that i'am about to fit! but i think i will struggle to mount the rears as they seem to overhang the standard rear mount but will keep you posted.
                            I think you'll find the BIG Reds are way too BIG for the standard 345 mm CSL front discs, as well :bigcry: I've tried that option first, before settling for the next BREMBO size down from the BIG Reds :thumbs:
                            I'll be interested to see how U get on :beer: especially with the rears :whistle:
                              Good read. Thanks for posting this up. I am tempted now:thumbs:Might have a look at ebay later.
                              Btw where did you get new discs for 100! that is a good price.
                                I did ring up simpsons about some pf discs and bells (ap) and csl offset 355 dia i think but the responce was don't waste your time so now i want to do it even more! I also found from the local porsche stealer that the gt3 disc dia is 334 and 32 wide! and looking at yours they do look the dogs nuts! I will have to get rid of the porsche logo though:thumbs:I think the discs came from euro car parts reading bellow.
