Porsche BREMBO 4 pots for the CSL ?
    hey noob here. I dont have a csl but got a m3 and very tempted to through with this upgrade as i agree the standard brakes are pants especially the m3s. are these mounts still available?
      PM sent
        Matt, how you find the RS4-2 pads in comparison the PFz pads?
        I am in process of doing this conversation and currently run PFz in the OEM caliper, but they do not offer a Z rated compound in the Porsche Brembo Caliper fitment.
        RS4-2s seem the logical alternative, but would like some feedback?
          PMed you back
            So finally I manned up :thumbs: and got my Porsche BREMBO callipers on the rear of the CSL (to go with the ones up front I've had for a while now :thumbs: ) to complete my BBK set up. First on road impressions are very good :thumbs: ... almost had an over enthusiastic and slightly too eager 335i driver through the back window :whistle: when he first failed to keep up with me only to be then out braked as well :banghead: just as his Turbos came on song... :gayfight:
            Some pix below
              Very nice mate :thumbs:
                Cheers Robster :beer: Not bad for home made, Pikey brake solutions :hahaha:
                  Looks great
                    hello guys, hope you don't mind me gate crashing this thread. ive read with great interest about this conversion and thought I would have a stab at it myself.
                    although my car is a e46 compact, there will probably be some similarities between CSL and "normal" e46.
                    my car has 345mm CSL front discs (ATE ebay special £250 the pair) and 328mm e46 m3 (OEM). the calipers came off a very nice boxster s and came with pads. the pads look quite new som I may use these initially until I can find some suitable track biased pads.
                    a couple of emails to rally road in the states to confirm which caliper bracket I needed, these are e46 non M fronts and e36 M3 rears!.
                    as ive written on here before regards rear handbrake assembly issues I wont bore you to death but I think its now sorted and will soon find out at MOT time if my solution was a success.
                    theres been much talk of machining calipers etc but upto now, I havnt seen anything with my set up to suggest any machining is required.
                    I could do with some advice as to which way round the rear calipers need to go, ive bought new Porsche link pipes from jasmine porschalink (very local to me) in order to swap round the bleed nipples but the calipers have two diferent sized pistons inside and wondered which piston is the lead piston. I know if they are incorrectly fitted there are uneven pad wear issues.
                    finally, don't bother with rally road brake lines, apparently, they don't stand upto much of our damp climate so instead, I contacted Porschecalipers for advice and they supplied me with some nice stainless lines. they also do the brackets but in my opinion, the rally road brackets are very well machined and the material they are made of is top drawer!
                    heres some (rather poor)
                    images. remember, its a compact
                    rear clipers
                    rear calipers are on
                    new link pies from jasmine porschalink (£67 the pair!)
                    front set up
                      I have a set of front and rear boxster s calipers from a 2002 model, anyone know whether these will fit? Also a parts list is much appreciated.
                      Thanks in advance.
                        Just came across this. Looks like a great upgrade without dropping a fortune on AP's. Any ebay links for these calipers ?
                          PM sent :thumbs:
                            PM sent :thumbs:
