Where are the correct mounting points for the use of a 6 point harness? The shoulder straps are to be wrapped around the rear harness bar. What are the required locations to install Lap & Sub belts, along with hardware end fitting, still using the existing 3 point belts. I know of there being alternatives but wanted a recommended set up.
Harness mounting points?
Would send you pics of mine mate but im at office and car at home, I have 6 point, and the actual inertia strap itself is still attached to car, ( Shim ! more weight to come out mate !!! happy days) but the floor mounted end isnt, so I am assuming that it gets used for the inside lapstap, I get a giggle when ppl first get in and grab the seat belt, then find that there is no where to attach it !:hahaha:... buts thats just me...you have to be there ! What harnesses have you gone for ?Originally posted by karbonkidWhere are the correct mounting points for the use of a 6 point harness? The shoulder straps are to be wrapped around the rear harness bar. What are the required locations to install Lap & Sub belts, along with hardware end fitting, still using the existing 3 point belts. I know of there being alternatives but wanted a recommended set up.
Cheers Dunc. I could see it amusing me too.Originally posted by DuncanR View PostWould send you pics of mine mate but im at office and car at home, I have 6 point, and the actual inertia strap itself is still attached to car, ( Shim ! more weight to come out mate !!! happy days) but the floor mounted end isnt, so I am assuming that it gets used for the inside lapstap, I get a giggle when ppl first get in and grab the seat belt, then find that there is no where to attach it !:hahaha:... buts thats just me...you have to be there ! What harnesses have you gone for ?
Pics would be great at some point, I am curious where your Lap & Sub belts fit to, along with what end fittings as there are a number of options.
