I snapped a spring in mine too, could be that if there's a wee bit of knocking too but otherwise, might be the topmounts on the rear struts or as above, RTAB's.
Not hard to do - 2 x 12mm nuts and 2 x 13mm nuts for each mount. Althought best to remove the diffuser first for easier access and make sure you have a good jack.
I can swap in and out a stock muffler on my car on my own with good tools and a big cardboard box and bit of contortion on my back and I am only a little fella :hahaha:
It's usually the driver side that goes first as it's a single mount vs the double mount on the passenger side. Sometimes it's the little U mounts on the intermediate pipe, but if those are gone then chances are the muffler mounts would also be perished.
They took it in today and fixed the battery cover in the boot! Said it was all fixed. Lo and behold I got half way home and found actually it was still squeeking just as much!:banghead:
exhaust mounts can go rear or mid car. rear can cause a rattle and mid can cause a knocking imho
a squeak is more likely to be suspension related or subframe mounts cracks which is a big job but bmw pay. If they check for cracks under the car near subframe mounts or in the boot they will find out pretty quick if they know what they are looking for
Cheers Shimmy. Booked in to go back next weds and will take a technician for a test drive so they can hear the noise. it's definitely not a knocking! They apparently checked over the rear suspension but clearly missed something.
