Hi,
SpineonBap- the CSL airbox is in three
sections.
If you remove the bottom 2 hex screws that
hold the 'funnel' part of the airbox onto the
where the flap is, and leave them out
then checking oil on the
dipstick is a 5 minute job.
The 'funnel' also fits on a lip so the 2
top screws are more than suffecient
to hold it in place.
All you have to do then, is remove the
top 2 'funnel' hex screws, disconnect the
electrical plugs to the flap, move the
SMG Fluid resivoir up out of its bracket,
then pull the funnel part out,
then remove the 4 screws holding the
second part of the airbox, which
are on the top lip, remove this, and you
can then access the dip stick.
Pending which strut brace you have
then just undoing one side and lifting
up, does that in a couple of minutes.
I removed the bottom 2 'funnel' screws the
first time I had to check the oil via the
dip stick and they will stay out.
Regards,
The Gorilla.
sections.
Regards,
The Gorilla.
