Brake fluid service indicator re-set
    Hi Lads
    Does anyone know how to reset the brake fluid change service indicator still reading 7/10 after a fluid change wanna get it to the next 2yr fluid service.
    Thanks
    You should have a little clock face in your display which indicates b/f due and can only be reset with a service reset gadget! Just make sure when you do it you don't reset the service indicator as well! try a local bmw specialist and if your lucky they might do it for a fee.
      1. Ignition key to position 0 (off)
      2. Hold trip meter button (the left button)
      3. Ignition key to position 1. The display will show: "test 1"
      4. Keep holding the trip meter button until the the display shows: "reset inspection" or "reset oilservice"
      5. Release the button
      6. Press and release the trip meter buton once. The Display will show the square clock symbol and the month the fluid change is due on
      7. Press and hold the trip meter button until the display is showing a flashing "reset". Then release the button. "reset" will keep flashing.
      8. Press and release the trip meter button once. The display will show the square clock symbol and the month for the next fluid change
      9. Press and hold the trip meter until "End" is displayed
      10. Let go of the button and turn ignition key to 0 (off)
      Instructions courtesy of GoingNuts of e46fanatics.com
        Good find :thumbs:
        Thanks
          I didn't even know that they had a brake service fluid indicator!?
            A little clock symbol comes up Dan,your stock M3 would have been the same.
              Excellent find mate, top man. Nice 1st post, now with an introduction, :thumbs:
                Is that when it says how miles left to inspection/oil service etc?
