What's the usual emissions test procedure for the CSL owners? As it's looking now, the Alpha-N conversion required to run a CSL box will not pass OBDII emissions testing in the states. Some states and even some counties within a state have different mandates but if you're car is required to be tested through the OBD port, it won't pass. I hope a way around that is found because that's the only real thing holding me back from converting to the CSL airbox
