Originally posted by cantfind1
The pump should pump constant pressure should it not, whether at 1000rpm or 8000rpm?
The regulator controls the pressure. I concur that a weak pump would lose pressure whether it was measured after the reg or not.
The reg regulates pressure, but if at say 7000rpm the pressure needs to remain constant, then the regulator will be trying to keep pressure at say 5bar, but the pump would have to work harder due to the amount of fuel being used, in order to maintain a constant pressure. A weak pump would mean a slight drop in fuel pressure.
I think a weak pump is only part of the issue, a poor designed tank setup is another.
I never had any issues in straightline driving, just out of sharp corners on 1/4 tank.
This to me says poor pickup design rather than faulty pump, in my case.
