Rear strut brace - options...
    Exactly, it'll stop the cracks as it triangulates the diff pick up points, also acts as a harness bar.
    As for the AC shitzer one, why would you need BMW to fit it - 6 bolts!
      Hi,
      Rear strut brace will be as much use as
      a Hand brake on a canoe if your still
      running a spring /shock rear end.
      Bracing a damper to another damper and
      the chassis does zero.
      If your running coilovers but no cage etc
      then it may make laetral rear end sway
      a little stiffer in the dry, when your about
      a wisker away from the rear end limit.
      As regards a rear end brace that bolts from
      rear strut tower to rear strut tower while being
      bolted to to the boot floor, that will make sure
      that the distance between the strut towers
      stays the same at about 1.2 / 1.5 lateral G,
      but I expect you would only be able to see
      that if running full slicks with a suspension
      set up that would be undriveable on the road.
      As regards picking up the rear diff, well if the
      diff is solid mounted then fine, but if not
      then somebody please explain to me how it
      works ?
      Regards,
      The Gorilla.
        I love The Gorilla :smt055
          Originally posted by The Gorilla View Post
          Hi,
          works ?
          Regards,
          The Gorilla.
          Agree with you Gorilla but my own personal reason for running a Safety Devices type rear strutt with floor pick-up is to, as Shimmy mentions, help prevent rear sub-frame cracking and brace the shock towers when running Intrax coilovers. Not that bothered with absolute on limit G's with slicks, etc.
          If running slicks a full cage would be essential, for me.
            You love everyone.:smt055
              Hi,
              AlexGTT- The rear strut brace will do nothing to
              prevent the rear subframe ripping out the boot
              floor, if anything it will accelerate it.
              The rear subframe seeks to leave the E46
              shell due to the ''torque twist' of the diff under
              extreme load.
              That is why the rips in the boot floor in most
              cases follow the same pattern.
              By stiffening up the rear end of the shell the
              loads when transmitted from the torque of the
              diff into the boot floor via the diff mounts will
              be greater as that area has been made more 'rigid'
              and the laods which can be partially disspearsed by 'flex'
              now have nowere to go.
              This will accelerate the point load, which is the sub
              frame mounts to the boot floor.
              Hence your 'ripping' dynamics increase not reduce.
              Regards,
              The Gorilla.
                Hi,
                extreme load.
                Regards,
                The Gorilla.
                hmmm doesn't sound good, was going to order one, nowI'm not sure. When I spoke to John though he said it was designed to prevent subframe cracking. What your saying does make sense but i'd like to hear what John has to say.
                After all, every race car they have runs one
                John?
                  Hi,
                  Unless the 'cause' of the ripping dynamics
                  is addressed, ie] the subframe mounts via the
                  boot floor, then no amount of 'stiffening'
                  to secondary panels is going to prevent it.
                  The rummour mill suggests that this issue
                  was addressed on later shells, but it is
                  an inherent design flaw.
                  The point being the harder the car is pushed,
                  reason for thinking about Thomas Fangdangle Strut Brace
                  in the first instance, then the more likely
                  the problem will be.
                  Unfortunatley these things sound so matter of fact
                  because they generally are.
                  Regards,
                  The Gorilla.
                    There are three seperate areas here:
                    1. Sub frame generated cracks in the boot floor
                    2. Running rear coil over suspension
                    3. Lateral stiffness running slicks
                    4. Running harness's
                    The harness bar/boot/suspension stiffener was designed for numbers 2,3 and 4 not specifically for no.1. As Gorilla says, the cause of this is a pulling motion and a strut brace etc wont really affect that. However, No.1 is covered by BMW's warranty (unless you run coil overs on the back) so our advice is to check yours is fine before fitting a strut brace or other upgrade (we do it as a matter of course on all suspension fitments). As the sub frame issue is well known and unrelated to anything other than diff movement on the floor BMW wont DK any warranty unless you have parts that will make this stress worse (slicks, coil overs).
                    In short, if you are worried about the cracking issue get your car checked, if its ok then mod away, if not then BMW will fix it under warranty. After this is you want to run slicks/coil overs/harness's then fit the bar.
                      was about to buy one, but with a asking price of postage @195 £, will do a different way :rolleye:
                        Listen, I'm the only expert round here, look at my Building degree!!!:thumbs:
                        Gawd knows what causes or cures the floor/subframe splitting for want of a better phrase, mines fixed by BMW at great expense to them.
                        Harness don't bother me as I gaffer tape myself to the chair anyway
                        My rear rear brace is to stop the steady twisting and flexing caused by rear coil overs on the turrets, meanwhile it would help with lateral support going as fast as I do:birdman:
                          Feckin' hell, alright Sebastian, pipe down.:hahaha:
                          Same reason as me Shim. Intrax.
                            I think the SD one also fixes to the boot floor near the diff carryo points, better but more work and a risk when it cone to warranty work on rear subframe (although with this fitted I doubt any cracks will happen)
                            got you, see what you are saying, just checked it out.
                              Yep, shipping anything heavy and bulky internatinally is a waste of time. Bored of TNT now but no-one else seems to be cheaper.
                                I sent a full exhaust to good ole u s of a with my parcel force acc for £120
                                I imagine belgium to be cheaper, Ill get you a price if you like to belgium:thumbs:
