Can BMW detect delimit/remaps?
    OK so it's a question that has no doubt been asked a trillion times, but I couln't find anything in the search function.
    So, if I had the speed limiter removed by somebody who new what he was doing (reputable tuner), would BMW's monkeys detect it at warranty/service time?
    My CSL still has 18 months warranty on it so naturally I'm a little nervous about having it unsheckled, but it's something I really want done.
    I've already verified that the limiter is there, which I didn't do at 05:00 in the morning on an empty stretch of the M74...:whistle:
    Oh and if it's undetectable, than can anyone advise someone that might be able to do it?
    Ta.
    whether or not bmw can find out if it has had a remap or delimit, i'm not entirely sure. but if your car is otherwise completely standard, they would not have any reason to check it.
    dms can delimit it for you. or you can find someone with a race license and get them to go to bmw with your car, he tells bmw he just bought the car and wants it delimited, and maybe they'll delimit it for him. as when the csl was released bmw delimited the car if the customer provided a racing license.
      Don't know technically if a dealer can interrogate the map fully but I'm sure they will have suspiscions if they feel like checking.....
      95% of maps have the sport button memory so that is a giveaway. :thumbs:
      Tbh though the dealers I have used would not look unless directed to by BMW for a major claim.
        Mark CSL has a good story about this...
          Perhaps one for offline?
          I'd certainly be interested to hear about it.
            The same here!
              So, I had my CSL remapped a few weeks back. I haven't modified a car since I was 20 years old and I'm one of these people who has never seen value in it. Also, the CSL is a bloody good car out of the box. So when it was discussed that my car be developed/tested for a remap, I went into it with no expectations and a fair bit of
              See post on that thread for executive summary. Yes BMW can detect it (doubt dealer can).
                A remap they can definitely detect (heck they can detect how many times you've scanned the car) ... not 100% sure about the delimit however. I am not 100% familiar as to how the delimit is done, but if my guess is correct it's simply a command within the control module that turns the function on or off. This is usually done via a BMW factory tool called NCS Expert which I happen to have.
                The functions are usually Activ or Nich Activ within the command line.
                So I presume that delimit would be listed in the commands lines and it'll just be an off or on switch. If that is the case, then yes they can see it if you've turned it on, but in a sense it's a functional part of the car so realistically it makes little difference to your warranty (think of it as function activation within your key EWS).
                  Hi,
                  As said BMW can detect most things on
                  the Siemens MSS54 ECU.
                  The more reputable 'Tunning'' companies
                  would suggest that the ''original Map''
                  was reloaded if the Car was in for
                  Service work etc.
                  The Problem with this is that there is some
                  form of encryption on the ECU that BMW can
                  scan which tells them how many times the
                  engine Map has been ''booted'' and ''rebooted''
                  Hence on count back from Service records etc its
                  very easy to detect if somebody has been
                  accessing the ECU.
                  On the E90 M3 the MSS65 ECU can actually count
                  and date everytime the ECU is accessed.
                  I believe it even detects in most cases what
                  has been accessed.
                  Some early Tuners who were accessing MSS65 via the
                  Diagnostic Port thought it was undectable.
                  Little did they know.
                  People forget, the ECU is a Mini computer.
                  Just because you believe you have covered your
                  tracks does not mean no trail exists.
                  Just ask Gary Glitter.
                  Regards,
                  The Gorilla.
                    I'm glad mine was done by BMW when new! :thumbs:
                      :bigcry: :bigcry: :bigcry:
                        My two pennuth !
                        If all you want is the delimit then surely there isnt a problem, as clearly its an official BMW option, and would not void the warranty.
                        Didnt in my case :whistle: .. which raises the question ...why dont I get the limit removed on the new engine ??? mmmm
                        Remap - another matter.... simple.
                          Even on the old E34 the dealers were able to tell if the ECU had been tinkered with as the Gorilla correctly states, they just use a countback / checksum approach. Luckily, you could just remove the secondary throttle cable which actually pulled the throttle back :hahaha:
                          Personally, I wouldn't re-map a CSL for what little gains it yields. And in terms
                          of removing the limiter, is it really that much use? Very little de-restricted stuff in Germany these days and in the UK, your looking at a day in court and the bus home. :hahaha:
                            Didn't know he had a CSL.:bigcry::bigcry:
