All your keys get reprogrammed at the
same time. Here is how it is done
1. Open the car doors using the remote function of your working key.
2. Get in and close (don't lock) all the doors.
3. Put the key in the ignition and switch momentarily to position 1 which is
the first position when you turn the key clockwise. This is the accessory
position. Don't stay in position 1 longer than 5 seconds; then turn the key
back to the off position.
4. Remove the key.
5. On the key transmitter, press and hold the unlock button. Press and release the lock button three times within 10 seconds while still pressing the unlock button.
6. release the unlock button.
7. The system indicates re-programming by locking and immediately unlocking
the door locks.
8. If you want to do more remotes, you must do each within 30 seconds of
step 7 for the preceding key. You just need to repeat steps 5 through 7 for
each key after the first."
PS If while you are fookin about with the above, the real owner wakes up and appears at the door, start engine, S6 , DSC off and give it the beans !!!!
4. Remove the key.
the door locks.
Do you know the sequence to activate the auto lock when you drive off?
4. Remove the key.
the door locks.
myself 2 second job in the end, just didn't want to end up wiping the code on the old key.
What happened the original spare key ? Might be worthwhile getting it barred / blocked (has to be done by dealer) as nothing stopping someone showing up with it and driving off in your car.
If it's barred it won't work the central locking or start the engine.
