steering u joint
    steering u joint
    having some troubles with mine, i have found this:
    seems to be the best part to replace the rubber, what do you think of this ? any alternative ?
    wich one (3/4, 1 ?) is good for the shaft ?
    Hi,
    Many Track and Race Cars replace the
    Rubber Guibo with either a solid
    Alloy spacer or a Delrin one.
    Just so you know, the Rubber is designed
    to split upon hard impact so that the forces
    generated should not push the steering
    coloum into the Drivers chest.
    Would be an ideal means for an Insurance
    company to walk away if it was discovered
    upon a big shunt.
    I have a solid one on my E30 M3 but the
    steering coloum picks ups are all altered
    and extra tube has also been welded in
    picking up the front Cage in Triangulation.
    Regards,
    The Gorilla.
