rear brembo conversion issue
    for all of us on here that have done the brembo REAR brake conversion i think i've found an issue.
    i fitted my rear calipers a couple of weeks ago with some mintex 1144 track pads.
    last friday i did a track day at donington park. after the trackday i checked the brakes etc and found the pads had worn very unevenly. ie the leading edge (bottom) of all 4 pads on the rear were worn almost to the metal while the trailing edge (top) was hardly touched.
    if it had been one pad i'd have thought stuck piston/stuck pad etc, but due to it being all 4 worn in the same way........hmmm
    now, hopefully a solution.
    the calipers on the m3 are mounted at the rear of the wheel. on the porsche they came off they are mounted on the front of the rear wheel.
    so the calipers on the m3 are mounted on the wrong side.....
    i think the pads have worn this way due to the different size pistons in the calipers.
    so, what we need to do is strip the calipers, remove the link pipe from the 'bottom', turn the calipers over, swap sides, swap the bleed nipples from bottom to top then fit the link pipe to the bottom. (we may need to make a new link pipe as the original sits in a recess in the caliper)
    this will put the larger piston at the top of the caliper, hopefully curing the wedgy pad problem.......
    That's exactly the case my friend.
    The smaller diameter piston needs to be the first 'met' in relation with the disc rotation.
    That's also why proper BBK solutions are... much better solutions and not workarounds.
      true. but someone has to be the first to try new stuff.
        Shame you've ruined a set of pads, but you should just be able to undo the link pipes and bleed nipples and swap them over, the link pipe may be embedded in some silicon which you can just pull out....:thumbs:
          Jim, I think the link pipes are threaded, just like the bleeding valves. Well I hope so anyway. :whistle: Unless I'm not reading what you wrote right :smt017
            I meant where the link pipe crosses over the caliper, they usually sit in a groove that some people fill with silicon....
            most calipers I have seen have the groove at both ends just so you can swap them for leading or trailing application braking solutions :thumbs:
            I'm not too familiar with porsche brembo's tho:clown: looking at daz's earlier pics - no groove..
            looking at these pics it should be possible to swap the link pipe, for the bleed nipples and refit the right way round....
              Ahhhh :smt115 I get Ya brav :hahaha:
              The BREMBO that have the cross over pipe groove at both ends are the older type callipers made of two halves, ones you'll find on early 911s (964s) and 968s.
              The BREMBO callipers in question here are the later mono block design and only have grooves at one end. :thumbs:
                The grooves are both ends so moving the link pipe is a simple matter of undoing it and moving it to the other end if it would come undone.
                So on my setup I had to cut the pipe tight to the union, undo the union with a socket and make new pipes....first attempt failed..made it to long so scrapped it and started again..still no biggie 6inches of brake pipe in the bin:hahaha:
                I haven't had the funny wear issue.
                Still getting used to them.... keep braking to early and having to apply gas to get to the stopping point..if you see what I mean:thumbs:
                  good work fella. i'll be doing mine asap
                    +1 ... Good work indeed :thumbs: Any Pix ? :whistle:
                    I'll do mine as soon as I've managed to kill my first set of pads :hahaha:
                      brake later and harder you big girl:blalalala:.....you'll soon get through a set:thumbs:
                        As soon as the CSL is out of Hibernation tomorrow :supz: I will :blalalala:
