alpha-n and fuel trimming
    Hello ,
    I own a normal M3 E46 with an MK airbox and an alpha-n reprogramming on the stock ECU.
    Although my car is running very nice , I have been checking through the GT1 module the adaptation values and I have discovered that the dme is making NO compensation what so ever on the injection time (both additive and multiplicative adaptation values are ZERO).
    I think that the MK alpha-n programming has "locked out" the fuel adaptation routines ...
    my question for all the csl owners is whether this applies to the STANDARD alpha-n programming of the csl , or not ???
    I mean does the csl make fuel adaptions (have you ever checked) or not ???
    thanks
    Welcome to the register Vaggeli.
    As I told you I don't know (haven't checked) but I can check with my GT1.
    Possibly NZ_M3 knows already...
    So if no one knows, I could plug it in this Sunday and check it for you.
    Cheers
      thanks Alexi !!! ... by the way do you happen to have the dme module for the csl as in comparison for the one for the M3 http://www.unofficialbmw.com/images/...lectronic1.pdf
        Hi,
        CSL does not run Alpha N as your now using.
        Load via the TPS which is then compensated via B/P.
        This should help.
        Regards,
        The Gorilla.
          Originally posted by The Gorilla View Post
          Hi,
          This should help.
          Regards,
          The Gorilla.
          Well ok ... when we say "alpha-n" on the M3 E46 we mean the same thing as with the csl ... of course there is a map reading etc etc
          as a matter of fact all Ms S54 (on the regular M3's) have an "alpha-n" mode that is triggered when the dme goes on safe mode or when the maf mall-functions or is removed !!!
          all the after market programmers base their "alpha-n" software for the M3 E46 on that oem routine ...
          on my car the dme bypasses the maf (which is physically removed) and the engine is constantly working on that maf-less software
          Other aftermarket maff-less software (since u seem to disagree with the use of the term "alpha-n") that we have checked ALSO remove the fuel trimming routine ... e.g the AA software ...
          On the other hand the "evolve" maf-less re-programming ,for instance, seems to be doing fuel adaptations
          So my question is pretty simple ... does the csl retain the fuel adaptation routine as the normal M3 or not
          So as to be perfectly clear I post a jpeg from the official MS S54 module for the M3 E46 where the fuel adaptation (additive and multiplicative) is depicted.
          In my car both adaptations are permanently set to zero
            Hi,
            Evangelos- Not sure I follow what your aim is ?
            You say that it ''seems'' that Evolve are
            using the MSS54 ECU for fuel adaptions ?
            Either they are or are not ?
            My understanding is that in the Evolve 'N' Map
            they also alter and optimise the Vanos settings
            and also alter the throttle settings so that on the E.gas
            100% throttle opening is acheived at
            the Butterflies. [throttle Pedal Peton /Fly by Wire]
            I find this a little strange as Butterfly TB's
            will deliver 100% of their capcity at something
            like 95/97% opening.
            Which I believe is the setting on the S54 from the factory
            with E.gas.
            You also say yours are ''locked out'' but
            that your Car is running ''really well''.
            So why do you want to re-configure something that
            is as you have said, running really well ?
            Your then asking if the CSL MSS54 is
            making fuel adaptions but state that you do not
            have a CSL ECU ?
            My understanding is that the facility exits in the
            MSS54 ECU and is working in part on the CSL.
            This is why the S54 M3 goes to N/A [MAF] and the CSL
            does not, the Emissions.
            Fuel adapation of a sort is also made on limp mode
            as the ECU is already working via load and pressure
            so can not revert to it, as with a MAF car.
            This all has something to do with the pan Euro Emission tests
            that the S54/CSL S54 had to pass as the Engine Emissions are not
            the same for both engines.
            So what am I missing here please ?
            Regards,
            The Gorilla.
              Sorry took me a while to get photographic proof to answer this question.
              There are many interpretations of what Alpha-N is. Personally I consider the CSL to be a quasi-Alpha-N setup (or as I would call it, Smart Alpha N :hahaha::hahaha: - because really, Alpha N on its own isn't really very smart at all is it haha).
              As for your question - easy answer - yes the CSL does make fuel adaption (trimming) in both additive and multiplicative: see photo below for proof (from my CSL). Hope this helps:
              And proof that the CSL is MAP based Alpha N:
                Cheers lads:thumbs:
                It's so much clearer now! :hahaha::hahaha::hahaha:
                T$
                  Originally posted by TANKSLAPPER View Post
                  Cheers lads:thumbs:
                  T$
                  +1 :hahaha: :hahaha: :hahaha:
                  My head hurts :bigcry:
                    Cheers lads:thumbs:
                    T$
                    Thicko!
                    Surely now you know what it is all about!
                    :whistle:
                      Hi,
                      Evangelos- ...
                      is as you have said, running really well ? ...
                      Well I don't want to change anything but I was curious whether the csl does fuel trimming or not ...
                      On the other hand I must confess that I feel a little worried about my dme making NO fuel trimming what so ever ... since this means that IF an injector or anything else on the fuel trail goes wrong there is no fail safe to keep the engine from running too lean ...
                      As for your question - easy answer - yes the CSL does make fuel adaption (trimming) in both additive and multiplicative: see photo below for proof (from my CSL). Hope this helps:...
                      Thanks man ... it is exactly what I asked for ...
                      Now since we are on the subject ... my opinion is that all "aplha-n" programmers that "bypass" the fuel adaptation routine (e.g AA or mine) do it so as to retain a given a/f ratio without having the ecu messing about ...
                      the main problem with "regular" M3's and maff-less proframming is that the dme takes into account on the fuel trimming adaption routine both the 02 sensors AND the maf ... so when u take out the maf it is probable that there is going to be a problem if u allow the dme to adapt ...
                      so they just bypass the fuel trimming ...
                      not the best of ideas but still u get a steady performance as long as the injectors , fuel pump etc are in perfect working condition
                        NZ_M3 hit the nail in head again :beer:
                          The knock sensors should theoratically come into play in a lean situation and knock back timing - so personally I wouldn't worry about it too much tbh (unless they've turned that off too? Possible if they are using the limp home map as the main mapping .. which would be stupid actually).
                          I can sort of understand why they've turned the trimming off - if you don't then over time the car basically 'reverts' back to stock tune, negating any benefits gained from Alpha N - the stock DME is designed that way for longevity.
                            The knock sensors should theoratically come into play in a lean situation and knock back timing - so personally I wouldn't worry about it too much tbh (unless they've turned that off too? Possible if they are using the limp home map as the main mapping .. which would be stupid actually)...
                            The knock sensors are working ... and the dme adapts the ignition timing ... however IF a lean afr occurs I don't think that any adaptation on the timing would change anything !!!
                              ~It might change it, but it might be too late.
