Does your water temp move at all on track?
    Just come back from the ring, had a good time but worried about a possible temperature issue...
    Here's what it did.. - bare in mind it was 25-27 degrees whilst doing this:
    I was running most of the time with the aircon off and the heating fans set to around 20 degrees at about half power.
    The temp gauge towards the end of the lap would be around the 2/3rds marker and oil around 125.
    Then on Monday they opened the F1 circuit aswell so each lap was just over 15 miles. My mate drove the CSL as he knows the track very well and when he drove we had the aircon on all the way round with the fans on nearly full power blowing cold, by about 2/3rds of the way round i noticed the water temp was almost in the red, and by the end of the lap it was just in the red, but after going under the gantry on the back straight and coming off the power coasting to the exit of the track it had already returned to half way on the water temp.
    This got me worried, although the only thing that made me feel slightly better about it is that his M3 was doing exactly the same, so I put it down the the hot weather and longer track, although i was still surprised it got as high as it did.
    The next time we went out, I put the heaters on full chat at 32 degrees, and had the windows open a touch to stop us melting, and by doing this the temp never went above the 2/3rds marker.
    I did some reading yesterday and saw Shimmys troubles and a few others on here and instantly feared the worst so I did a compression check this morning.
    Results are fine and don't show any signs of a HG failure which is a relief, but im just worried now about what else it could be.
    I'm guessing you boys don't do all hot track days with the windows open and the heaters pumping at 32 degrees!
    Any help and suggestions much appreciated
    Another thing to note - my temp gauge never seems to sit bang in the middle either, normal driving it sits just under the half way marker and then a spout of hard driving you can actually see it move to just over the half way.
    Could this all just point to a dodgy thermostat?! :hahaha:
    My guess would be that if oil is going over 2/3 followed by water going over 3/4 towards red then HG is favourite. I'll be surprised if its not even if yo have checked it.
    Very common on high mileage cars, Dunc, Rob, me, Daz, and a few other have had HG changed.
    I think early symptom if high temps on track on hot days first.
    Get compression test asap (cylinders 5/6 will be worse) to rule it out before you start, like I did, rafting around with stats, rads, water, fans, oil coolers,
    My car used to do hot days with a/c running no temp issues the slowly on hot days on track it started creeping up. Since HG changed no issues
      Well like I said i did fear the worst and so got the compression test done this morning - results are as follows (bare in mind the engine was not red hot so readings are a little low across the board)
      1 - 149
      2 - 154
      3 - 155
      4 - 157
      5 - 159
      6 - 151
      So whilst I appreciate what your saying I wouldn't have thought the above results would suggest a HG?
      Any other thoughts?
      Also whilst doing the compression check we couldn't help notice the pollen filter had not been replaced for a very long time... but it's just had an Inspection 2 :smt083
        Shouldn't compression tests be done hot?
        I couldn't replicate my overheating anywhere but on track, warm day, full power.
        Cleaned rads, replaced stats and sensors, viscous fans, etc etc. US forums have loads of this and if you think about it if you only get it at full chat, warm day, so plenty of air and fan is not an issue. Temp of oil ruses first followed by water so it seems to be engine caused not water cooling system.
        I narrowed it down to injectors, map or fuel related. Removed Map and still happened then HG failed proper and after fixed it never happened again
          Yes ideally - it wasn't done cold, just not as hot as it should have been. Was rushing and the engine had cooled for an hour or so because i realised i didn't have the right adapter to reach down the thin spark plug access holes and connect the compression tester.
          Anyway, for a HG check it doesn't matter too much if the car is not red hot, as your looking for anomalies between the cylinders. Hot readings would just show around 15psi higher on each cylinder.
          It does make sense what you say with regard to oil temp rising first causing the water temp to budge, although the other M3 that was with us had the same sort of oil temps 125/130 but his water temp didn't budge at all. :smt102
          I'll give Simpson's a ring on Tuesday and see what they think...
          Didn't you end up replacing your engine shortly after the headgasket Shimmy? was that the result of damage caused by the failed headgasket in the first place?
            No, bottom end, spun a shell.
            If you look at the gasket the spaces between cylinders are very small and my belief is that when engine gets warm/ hot the compressions between the two cylinders drop very slightly when at full whack and you get overheating at 100% throttle.
            My original throughts Were that the occasional near overheating caused the HG failure but as I never found a reason for the overheating and it went away at that time, I can only conclude the reverse.
            As you car is higher than average mileage and you get E46 with 60-80k miles ith HG failures pretty commonly now days that have never been on track, i personally would do a thorough check first.
              Just an aside - in all the reading I've done about this on UK and US forums, it never seems to be replicated on road but only on track in warm weather. Obviously high numbers in Southern American states.
              I think road going cars don't ever get this syptom and go straight to misfire and pinking on HG failure at a later time.
              (oh and I changed the water pump on mine, cleaned out rads, inside and out as well and no joy)
              Yours could be a differet thing but tbh a 110k miles might be worth HG change anyway!
                [slightly OT]
                With my M3 E36 3.2 I had problems with oil temps going too high the last two - three years (on track only), it got slightly worse each year. It was a damaged oil cooler thermostat. With it changed all went back to perfect.
                [/slightly OT]
                In my CSL I have a problem with the water temp going high sometimes on track. Dropping back the driving tempo slightly just half a lap makes the water temp go back to totally normal (normal = not 100% straight up but thereabouts). Oil temps go up a bit on track but just a bit and never more than that. I had no idea where to start, but checking the comp sounds like something I should do then?
                  So James, remind me what it was you were saying about your car being a safer/more reliable bet than one which had been tracked in the past? You've had a few issues now... :whistle:
                  On a thread related note, I have never had any overheating issues on my car; not even before my HG went recently.
                    Sorry Rob, I thought. Said above you have to drive it flat out and at full throttle to get it......:whistle:
                      We had this discussion in another thread.
                      The water temperature should never move higher, on track full speed or not.
                      You car has a problem (radiator, water pump, head gasket / 1 or more..).
                      Get it checked.
                        is it not also the case on high mileage cars like robs....:blalalala:
                        Get it checked.
                        be told James
                          I have a feeling... (and I'm hopeful I'm right) that it could just be the thermostat.
                          Reason being is I was driving it this evening and kept an eye on the temp, it got up to the middle but then went down and sat just a bit to the left of bang in the middle 'where it should stay all the time'. When I hit some B roads the temp went to half way and then maybe 1mm to the right of half way and when I backed off it came down to below the half way point.
                          This leads me to believe its the stat as it's actually overcooling at some points and not cooling enough at others. If the HG had gone or anything like injectors or water pump it would surely ALWAYS run too hot and never too cold like its doing?
                          Anyway, i'll get it checked out, but less worried about it now, we'll see what a thermostat does :smokin:
                          Thanks for the replies though boys :thumbs:
                          And Rob - yes I did say that, but mine hasn't had a HG yet and yours along with a few others on here that have done half the miles have so that's all I was getting at. Never made it would be problem free...
                            My temp gauge can be slightly to the left but never goes higher than half way could well be thermostat, but would prob do head gasket change on yours due to mileage and that you will be tracking her.:thumbs:
                              You should have bought bealos with ap and warranty :whistle:
