Sport Button thoughts.
    Originally posted by _Nathan_ View Post
    Nothing to do with high revs and low revs?
    ok, so its the amount of pedal travel i am on about (didnt soemone post a table of pedal travel to throttle opening sport on and off recently)
    what im getting at is that if the car is harder to control at initial pedal movement with sport on surely it is easier to control at the bottom as it has more travel for less throttle response
      Hi,
      The E.gas [Fly by wire] is controlled by
      the thottle inputs to the engine load.
      The E.gas Stepper Motor, is a linear motor,
      it opens and closes the throttle bodies as there is no
      throttle cable, which is via the input signals from the
      Throttle pedal potentiometer.
      ie ] Right foot input.
      When the Sport Button is engaged, the
      ECU alters the amount of fueling,
      so that more fuel is allowed into the injectors.
      Thus at equal throttle openings, but with ''Sport mode''
      ''on'', the engine gets more fuel.
      Unless this fuel is burnt it will make for a
      ''Jerky'' ride as the ECU detects unburnt fuel and
      cuts the fuelling to the injectors.
      And so the ''Jerky'' cycle continues.
      As Lawsy said, smoother pedal input loads will help,
      as for a smaller pedal movement the engine
      receives the same amount of fuel,
      or its foot to the floor, and away you go.
      The more you try and 'modulate the pedal'
      in Sport mode the worse it gets.
      Its part of the reason, although most of the
      ECU brigade diagree, that I prefer an S54
      with a Throttle cable.
      Reason being is that on Track coming out of
      slower corners its much easier to feather the
      throttle modulation to keep the engine well
      in the Rev band without getting into issues
      wherby throttle inputs get your right foot
      ahead of the E.gas Stepper motor.
      Regards,
      The Gorilla.
        End of
        Topic closed :smt023
          CSL sport only alters throttle. Thats it.
          Not true Lawsy ... it fooked my steering up once !!!! :hahaha::banghead:
            The Primate has spoken :smokin: If anyone is still unsure, best you get your coat :hahaha: The End
            Originally posted by The Gorilla View Post
            Hi,
            Regards,
            The Gorilla.
              ...(didnt soemone post a table of pedal travel to throttle opening sport on and off recently)...
              I have seen a graphical representation of it somewhere & know what you're getting at :thumbs:
                shim
                  And here's me thinking it was something to do with the Flux Capacitor????
                    Hi,
                    Who complied that Graph please ?
                    Reason is that its incorrect.
                    A TB will give its max performance at
                    something like 92/93% of opening.
                    The reason is simple the ''butterfly''
                    obstructs the flow path so it can
                    never give 100 % throttle opening
                    it can only give 100 % on the Throttle
                    angle.
                    Therefore, accordingingly the Graph
                    would be showing 100% throttle angle
                    which in real terms would be approx
                    93% open Butterfly at 80% of Pedal travel.
                    The M3 Throttle Pedal has a detent set
                    at something like 95% of travel
                    for this very reason.
                    Some alter the Throttle pedal detent thinking
                    that the final 5% pedal, will give more power,
                    when the Throttle bodies are already
                    maxed out at 95% of butterfly opening.
                    Regards,
                    The Gorilla.
                      Hi,
                      Regards,
                      The Gorilla.
                      Hi
                      Searched google, something like 'e46 m3 throttle position sport mode', images only. Gives 3 or 4 different graphs different sources.
                      eg http://forums.m3cutters.co.uk/showthread.php?t=5850
                        This thread would be more interesting if it was sports illustrated
                          Shimmy has a lot to answer for... :bigcry:
                            There's an app for that :thumbs:
                              Hi,
                              angle.
                              Regards,
                              The Gorilla.
                              i thought you said it was fuel related and nothing to do with pedal/throttle opening changes!
                                Hi,
                                Shimmy- you have me confused.
                                All I said was that the Graph was incorrect
                                in regard of the data provided.
                                I then gave some paramiters to explain
                                why I said the Graph was incorrect.
                                Last I explained the Throttle
                                Pedal 95% v TB's at full throttle.
                                I still maintain that the Fueling is increased
                                on the ''CSL'' Alpha N type set up
                                with the Sport Button on.
                                Reason being due to the Adaptive
                                fueling of the CSL ECU, that the std
                                M3 does not have.
                                On a standard S54 with MAF then its
                                throttle pedal angle v throttle angle,
                                over the Mid range only, which is all that can
                                alter, as the TB's are closed at the
                                start and open as wide as they can
                                at full throttle.
                                The start and end points are fixed.
                                ie] Pedal off would be zero, and
                                pedal fully depressed [95% to detent] would be
                                100 % of Throttle angle with
                                Butterfles giving approx 93/4% flow.
                                Go drive a Std M3 with sport on
                                and then go drive a CSL with
                                sport on.
                                Reagrds,
                                The Gorilla.
