Brake pedal issues.
    Brake pedal issues.
    I tracked a csl with ap brakes front and rear and the pedal distance was very short and the feeling was too hard. This is what i want from my brakes.
    I have Alcon csl cup kit on my car and the brake pedal isn't the same with Ap. I don't know why..I am using motul rbf 600 brake liquid and pagid rs29 pads.
    Any ideas?
    Alcons will give longer travel compares to APs. Im not sure what can be done here to be honest.
      +1
      = Sell Alcons, Buy AP - :clown:
        Could try RS14 or 15. IMO they have quite a bit more initial bite which may give you what you want, saying they do them for those calipers. Just an idea.
          Hi,
          Has your master cylinder been bled
          with a power bleeder just so
          there is no air whatsoever in the system ?
          Do you have a balanced set up, ie
          front and rears or just fronts ?
          If you have just fronts, then a 'balance valve'
          to the rears might help,
          If Brakes have been power bled then its-
          Pedal Ratio V Brake Master cylinder size
          V Caliper piston sizes V swept fluid volume.
          I do not know if there is another BMW
          Brake Master Cylinder which will fit
          the E46 M3 Servo and is slightly smaller
          size than the std M3/CSL ones,
          so as to increase Brake Pedal pressure which should
          in theory give the Alcons a stiffer pedal
          feel.
          Slight downside is that pedal pressure will have
          to increase on the std fixed pedal ratio.
          ie] more left foot pressure.
          Regards,
          The Gorilla.
            The Alcon pedal feel is shit if I am honest. AP are far better.
            The master cylinder needs changing, but as G man says, I dont know of a different one to sort this out.
            Fitting a pedal box with correct sized cylinder will of course work, but major overkill in a road car.
            I power bled mine in all manner of sequence, it was always the same.
            But they work, so use them, they feel better for road use as they are not as snatchy as the AP, they also work great on track, but dont inspire as much confidence as the AP due to pedal feel/travel.
            I have said this for a long time about the Alcons, people are slowly starting to see my point.
            That said they are still far far better than stock set up for track use.
              I have front/rear setup.
              I was thinking the solution of pedal box with two master cylinders or one with two exit hoses, as i am using the car 99% for track. But i am not sure...
              Alcon brakes are excellent on track.
              Ap's pedal feeling is like drive a kart!
                Hi,
                Manos///3- If you go with a Bias Pedal Box
                or some type of dual cylinder set up then you
                will have to loose the std Brake servo
                which will effect pedal ratio/ pressure for
                the ABS.
                Remote servo ?
                While you will be able to play around with
                the master cylinder sizes, and pedal ratio,
                its not without its own set of issues.
                No free lunch.
                Regards,
                The Gorilla.
                  Gorilla without servo means that ABS should be working more often with less pedal pressure?
                  What are they do in motorsport world?
                    Hi,
                    Mamos- The 'BMW MS Racing ABS' is
                    streets away from what you have
                    in your car.
                    The BMW MS ABS is around 8/9k if I remember
                    correctly.
                    It has variable settings for Modulation
                    etc.
                    To set up the std ABS system with
                    a bias pedal box arrangment and no servo
                    will not give a 'pedal feel' anything like
                    the AP's that is for sure !!!
                    I have never driven a M3 with Alcon Kit
                    but from what Lawsy and you are saying
                    its like there is more pedal Travel before
                    the bite/pedal resistance is felt ?
                    The std Servo / ABS system is very good
                    so why not fit the Brake Pedal assembly
                    from an Auto E46, stronger and better
                    pedal offset.
                    Then fit a Brake Bias Valve into the rear
                    brake line, mount the valve adjuster in the car,
                    centre console or whatever.
                    Then in the dry you can increase the front
                    bias which might assist with pedal feel/ response
                    as taking away some rear bias in the dry will
                    not alter very much, and then in the wet you can
                    give more rear bias, which is what you want
                    anyway.
                    200 or so Euros if you do it yourself.
                    Regards,
                    The Gorilla.
                      BMW Motorsport ABS is a bloody nightmare. Don't think it costs anywhere near that much but the software is incomprehensible and the documentation is rubbish.
                      The actual unit is Conti Teves MK60 so same as road car but different software.
                      From what I have seen so far Bosch far, far better, and far cheaper than the prices you have given. On the fly adjustment too via a driver controled switch allowing them to select from different settings for different conditions. Documentation and support a world apart.
                        I run the Alcons in my car and have a friend here locally that recently installed the APs and I had the pleasure of driving his car on the track in anger, I cannot for the life of me discern any noticeable differences in pedal travel between the two (if anything the Alcons probably had shorter pedal travel), I would actually say that the two kits are quite comparable and very similar in performance. I will admit however that there is a slightly appreciable difference in overall brake balance, but hardly anything I would call substantial.
                        If you look at the maths between the two brake kits in contrast to the factory setup, you'll realise there's very little change in terms of brake bias and overall piston volume (i.e. the fluid being moved within the calipers) - let me give you some facts to go on:
                        Stock CSL front brake piston area: 54.7cm2
                        Alcon front brake piston area: 56cm2
                        AP front brake piston area: 50.1cm2
                        Stock CSL Rear brake piston area: 33.2cm2
                        Alcon rear brake piston area: 32.2cm2
                        AP rear brake piston area: 22.9cm2
                        So as you can see, the Alcons do move slightly more fluid, but hardly anything outside of the working bias range between the stock set up.
                        The stock brakes have a front to rear bias ratio of 1.73:1
                        The Alcons have a front to rear bias ratio of 1.78:1
                        The APs have a front to rear bias ratio of 1.69:1
                        I am putting it down to a worn master cylinder or incorrect bleeding causing your pedal travel woes - I've had my kit for a while now and I have certainly NEVER experienced that you or Lawsy have claimed to have experienced.
                        Don't get me wrong, the APs are great, and if I get to do it again I would probably pick the APs over the Alcons (for more brake pad options and easier pad change), but the two kits really are quite comparable.
                          Very useful information from you guys! Thanks!
                          The other question is what will happen if i remove dsc -and abs of course- ?
                          Master cylinder straight to calipers.
                          I never use dsc in track and abs never intervenes on dry conditions.
                            Hi Mano,
                            The brake area values that NZ_M3 has shared, show a lot.
                            The smaller the area is, the less fluid you need to move the pads for the same distance.
                            The less fluid you need, the less brake travel you need.
                            You could deal with your problem by putting a master cylinder with bigger piston diameter.
                            Maybe a unit from X5 or 7 series is bigger, but you need to be sure that the dimensions are compatible with the E46.
                            Removing the DSC unit from a road car (with normal road loom) is a bad idea in my opinion.
                            You will get a lot of errors from the DSC module, issues with the sensors and possibly SMG issues (it's using input from the DSC speed sensors on the wheels).
                            But going back to the basics, who did the brake bleeding and how ?
                            As I have explained in other posts, in order to do proper bleeding in the E46 (especially when changing calipers / lines that the DSC unit runs out of fluid) you need to use the GT1 diagnostic unit and open/close the valves of the DSC unit.
                              Hi Alex,
                              I did the brake bleeding using the gt1 twice!
                              I know the procedure with dsc.
                              I will make a research for bigger master cylinders.
                              Thanks!
