Nô warranty in France after 5 years! We all pay a lot to run the Csl ! This problem is just following the "normal" rupture of the hose ! steering pump + hose + rack= 3000 € !!!!!! i have to bé in love with it to keep it
steering rack
had to take a plane, shake these white collars at the factory in munchen, had some beers, pick up the steering rack, had some beers, take the plane back to france, had 1 beer, and mollest my dealer !
no, there was just 7 left at the factory. my dealer had to send some fax and mails in germany. he finally received it this morning.
ask the official csl register dealer (murkett ??) to order 2 or 3, just in case.
it is based on an exchange, you can't keep your old rack
As you may already know from my post in "Hi to new members", my car was converted from RHD to LHD. Now I just learned, that the CSL steering rack is twice the price than a normal M3 rack.
Hmmm. I get a little bit unsure, if they really build in an original LHD CSL rack.
So, I just turned the wheel: It is exactly 1,5 turns from center to full turn in.
:smt017 So, please enlighten me: Is it a CSL rack or just a "standard" M3 one? :smt017
Chris
I believe a CSL rack is different and like a Z3M rackOriginally posted by ChrisCSL View PostAs you may already know from my post in "Hi to new members", my car was converted from RHD to LHD. Now I just learned, that the CSL steering rack is twice the price than a normal M3 rack.
Chris
Hi,
Sounds like you have E46 M3 Rack.
E46 M3 is 15.4.1 which is approx
2.95 turns lock to lock, so
approx 1.5 each way.
E46 CSL is 14.5.1 which is approx
2.7 turns lock to lock.
A Z3 Rack from a 1.9 to 2.8 engined car is almost
the same as the CSL rack, just a fraction
slower, you would never notice it
but the Z3M rack is slower at 3.0 turns.
Z3 Rack will bolt straight in as well and you can
use the same outer tie rods etc.
Regards,
The Gorilla.
Thank You!
Yes I definitely don't have the CSL rack.
Made a quick and dilettantish simulation:
Thats a CSL rack, full lock at 126 degrees
By chriscsl at 2012-05-08
and M3 rack, full lock at 171 degrees
Quite a difference. For sure more than I had expected.
I think this will be my project for the next winter
:supz:
As a quick point the lock to lock turns of a steering system is not a guide of ratio as it depends on rack travel. BMW have a history of having different rack travels on their M cars to restrict lock to account for bigger front wheels and tyres, and this affects the lock to lock measurement.
Only way to properly measure the steering rack ratio is to measure rack travel vs pinion angle, this is how rack ratios are specified in the industry. So for a straight non variable ratio you can measure rack bar travel per one turn of pinion, you end up with a figure of mm/rev.
The steering wheel to road wheel ratio, quoted as a number like 15:1 etc, is affected by both the phasing of the column universal joints and the amount of ackermann the car produces.
And last point, if you have a car with variable steering ratio like a lot of modern cars, (and the original E36 3.0 M3), you can measure a small lock to lock amount which misleads you into thinking it has a fast ratio, when it actually has a slow ratio on centre that speeds up towards end of lock.
