Head gasket and oil leak!!
  • shane@mbtech
    Fit a motorsport/tropical thermostat and see your water and oil temps run a lot cooler.
    Far far cheaper than an oil cooler, but helps a great deal. :thumbs:
    Running both will be even better still.
  • shimmy
    Try around £2k... :banghead:
    I'll be having an uprated oil cooler fitted by Simpson soon :smokin:
    Rob
    Julian was Looking At a £300 Solution when i spoke to him At Brands.
    Let's get him to Finalise His Plans for The Budget fix AND do 2
  • glendog74
    Originally posted by plug View Post
    HG can be expensive:banghead:
  • plug
    I'm leaning towards oil cooler:smokin:
    HPF do a nice one, a bit expensive though. Fuck that though, maybe a new radiator along with the oil cooler will solve peoples problems? HG can be expensive:banghead:
  • jibm
    could be the answer to my oil leak perhaps?
  • AlexGTT
    :thumbs: Since mine had slight tendencies to rise water temps two years ago I've had no such issues since fitting improved oil cooler.
    Not saying it'll solve everyone's issues, just giving my experiences.
    As Shim mentioned, the OP should get compression checks asap.
  • shimmy
    Ah ok.
    I wonder between having a better oil cooler and bigger radiator would it cool the engine enough on track days to prevent head gasket failure? Might be worth an investment to some folk.
  • plug
    HG failure on S54 is common between cylinders, not to coolant.
    Ah ok.
  • shimmy
    Can you open the expansion tank and give it at bit of a smell, if there is a right bad smell off it and if it is discoloured(darker than normal), it could be the head gasket. Also check under the oil cap, if there is cum looking stuff that also points to the possibility of a HG failure but in most cases not.
    Do a coolant pressure test anyway. I'd say the mechanics will carry out more tests also unless they are slow.
  • shimmy
    Originally posted by northernjim View Post
    HG failure does happen tho shim and its bound too ( IMO) with the tiny distance 'tween cylinders and years of heat cycling.... tracking just quickens it I think
    I know, I've had that already, and high temps on hot trackdays before, but just not convinced it is a sign of HG failure.
  • Pazuzu
    Originally posted by jibm
    The easy thing i hear you say is put it back in, but unfortunately the flap has gone missing during a house move and i cant find it anywhere!!:bigcry:
    Thoughts gents please?
    Hope you get it sorted ok.
    I think I've got the flap for mine lurking somewhere in the garage so if they give you grief and you need one just give me a shout.
    Cheers!
    Phil
  • northernjim
  • plug
  • jibm
    It's debateable of HG failure is a result of overheating (which it can be) or the cause, i am in two minds but get compression test and check just incase.
    Did you notice oil temps rise first followed by water temps?
    It was a very hot day, oil temp stayed at just below 2/3 most of the time
  • shimmy
