Track day - what tyres?
    Hi guys, just picked up my CSL and am thinking of doing a trackday in it.
    It currently has nearly new PS2's, what are these like on track? I am not after out and out grip, but I do not want to destroy a grand worth of tyres!
    Has anyone been round snett on PS2's? If so, what were your thoughts?
    Olly
    Olly
    PS2s are not bad as a track day tyre. Ok, they don't offer the ultimate in-corner grip of the Pilot Sport Cup tyres or similar but they do stand up to some real abuse and react nice and progressively during cornering.
    The one thing i will say is make sure your car's geo is checked and set up properly and do not run a road based setup as you will wear the outer edges of the tyres when you push on a little more. If running standard suspension you should consider fitting Turner adjustable camber plates and spacing the front wheels by 10/12 or 15mm.
      Thanks glen. AS far as i know it will be a road setup I am running.
      I think I may just turn up and see if I can get on for half a day..?
        As Glen says, PS2s are very good on track.I would do a couple then progress to Cups.:smokin:
          Will I knacker them?
            Wouldn't have thought so, not on your first trackday and if its wet you'll be glad you had them.:thumbs:
              Best get it booked in then!
                if you are careful they should be ok.
                it does depend on you as a driver plus geo and tyre temps/pressure but it comes back to if you are a careful
                type or a lunatic
                  type or a lunatic
                  Lawsy comes to mind.:hahaha::hahaha:
                    I did a day at the ring and a day at Spa on my very well worn ps2 (about 3mm when i started) and they were just about legal on the drive home but really need changing. I expected them to wear a lot quicker than they did.
                      olly if they are nearly new flog em and get pss all round or get a second set of rims with cups for td's only check out robdogs rear seat removal thread and youve got a good choice come rain or sun
                        any advice on tyre pressures?
                          Fronts: 31/32 hot
                          Rears: 32 hot
                            I will buy em off ya as long as they are down to the canvas !!
