M3 DBW throttle motor photos sought
    Looking for detailed photos of the DBW M3 throttle actuator motor and set up, as I am thinking of using it on another multiple throttle body straight six engine. Thanks
    Hi,
    Its just a Stepper Motor that is
    bolted to the side of the engine
    block.
    It has a rod with plastic rod
    ends, that attach the stepper
    motor to a link on the main
    bar that passes through the TB's.
    All the workings are really in
    the software which reads
    via the TPS and the Throttle
    pedal Peton [6 or so wires].
    Regards,
    The Gorilla.
      Thanks, would still like to see photos. What does it use for the feedback position sensor, a separate pot to the throttle pot, or combined? I intend running it off my M800 Motec ecu, which has DBW enabled. It's initially to go on an RB26 Nissan engine, then one is going on a Bonner V6 race engine, which has a slide throttle. Cheers.
        Hi,
        I believe that Motec now have a Map
        that will drive the Stepper Motor and
        compensates via engine temps so you can
        program / set the ITB's for Idle
        at cold and they calibrate via
        the opening/position of the
        stepper motor when warm, as
        opposed using the Idle Air
        Intake Valve etc.
        Otherwise I am guessing your going
        to have to fit some sort of Idle valve
        set up for the ITB's.
        I have no pics of the Stepper Motor
        in-situ, and the Air Box needs to be
        removed for a good picture.
        Is there nothing in the Pic Gallery ?
        I run a Manual Throttle on another
        S54 engine [6 pot] and find it much more
        linear than the E.Gas / DBW.
        I would guess that your looking
        for the ability to be able to alter
        Throttle angle V Pedal angle input ?
        Personally I prefer the crispness
        of the Cable, but each to his own.
        Regards,
        The Gorilla.
          Warm up compensation and idle speed control won't be an issue on the RB26 as it has an idle control valve as well as the throttle bodies, and the other is a pure race engine, so no idle control is really needed there. So does the positon feedback to the ecu come from a single throttle position sensor, or has it a dedicated one for the DBW, as well as one for the main fuelling / ignition mapping in the ecu?
          It's mainly to allow implementation of traction control via throttle opening.
            Hi,
            The S54/CSL just runs the single TPS
            and a Pressure sensor with Air Temp
            for its Bastardised Alpha N.
            The standard S54 / M3 runs a single TPS
            but usees a MAF on the Intake
            as it does not run a Alpha N type map.
            The Siemans MS S54 ECU defaults to
            Alpha N for Limp Mode.
            Will see if I can dig out a pic for you.
            Regards,
            The Gorilla.
              Hi,
              Basil- couple of pics of the Stepper Motors
              and linkages from BMW S65 M3 Engine [V8]
              The principal for the S54 [L6] is exactly
              the same, many of the connectors and
              linkages etc are common to both engines.
              The Stepper Motor fits on the side of
              the engine as opposed in the V8 on the
              S54.
              Hope that helps.
              Regards,
              The Gorilla.
                Sorry for the delay, for some reason I didn't get, or maybe see, a reminder by e-mail of you latest reply. That's exactly what I am looking for, sincere thanks for your trouble. It looks as if that drive motor might just do the job, certainly with it having a link arm if adds a good degree of installation flexibility. On the M3 unit where are the pots for the DBW feedback, in a combined casing on just one end of the throttle shaft?
                Again, thank you very much indeed
                  Hi,
                  Yes, the S54 has the TPS at the end of
                  the bar that links all the TB's Butterflys.
                  See pics.
                  I used the S54 TB's on this project
                  but have gone with a Manual throttle,
                  as the ''DBW'' is always an option at
                  a latter date.
                  Regards,
                  The Gorilla.
