Yellow Oil Light
    Not yet, missus has gone to the shops for Peroni though
      Originally posted by _Nathan_ View Post
      Yes, if you look hard you can see it.
      :smt043
        Nath
        Even my mrs laughed at that one.........:hahaha:
          :hahaha: :thumbs: :hahaha:
            A beauty, very good Nathan :thumbs:
            A bit of lighthearted humour before the heavy, technical stuff begins again... :hahaha:
              That's what I'd call an antidote :bigcry:
                Originally posted by The Gorilla View Post
                Hi,
                Extract -
                ''13. Worn Valve Stems and Guides
                When wear has taken place on valve stems and valve guides, the vacuum in the intake manifold will draw oil and oil vapor between the intake valve stems and guides, into the intake manifold and then into the cylinder where it will be burned. If this condition is not corrected when new piston rings are installed, an engine is likely to use more oil than it did before because the new piston rings will increase the vacuum in the intake manifold. When gum or deposits on the valve stems are removed – a procedure recommended when overhauling an engine – the seal previously formed will be removed and leakage will be more pronounced. This is particularly true on overhead valve engines where loss of oil may occur on the exhaust valves as well as on the intake valves. High oil consumption caused by too much valve guide clearance can frequently be cured by reaming or nerraling the valve stem. In some cases new valves may also be required. Use of a permanently bonded valve stem seal will give added insurance against oil leakage on complete engine overhauls or on valve jobs.
                Cantfind1- have a read you might learn something.
                Might also explain why you have oil contamination in
                your CSL Plenum and I do not.
                Regards,
                The Gorilla.
                Is this an extract you made up yourself? Did you ever go to university?? Where is it from??
                I am not doubting that worn valve stems will let some gas escape, however lets compare the size of a piston to a valve stem, which one is bigger Primate, or are you not evolved enough to work that out yet, you know square peg round hole and all that?!
                90% of an engines blow by comes from passing by the piston rings and they do not have to be worn for this to happen it just happens whatever the state of the bores or the piston rings.
                The reason why this gas is worse than the gas that passes by the valve stems is that
                1 There is a lot more of it.
                2 It passes straight down into the crankcase and mixes with oil fumes.
                Valve stem seal gas escape is negligible and is basically exhaust gas, ie no oil vapour!
                By the way you are right I have learnt something reading that.....You have absolutely no idea what you are on about!
                  Is there vacuum in a Csl carbon air box?
                  I think you already know the answer to that one mate.....:smokin:
                    Hi,
                    Cantfind1- funny how when something contradicts
                    what Cantfind1 says, its dismissed or you spout
                    its made up, simply remarkable.
                    Worn exhaust valve guides can allow
                    excessive oil to pass by so its not just
                    ''Gases'' as you allude to.
                    Size of the piston has nothing to do it with,
                    if you were running total seal intermeadiate
                    Rings but had worn valve guides /stem seals, the blow
                    by from the valve train would far more
                    excessive than the combustion chamber.
                    Regards,
                    The Gorilla.
                      Originally posted by the gorilla View Post
                      hi,
                      cantfind1- funny how when something contradicts
                      what cantfind1 says, its dismissed or you spout
                      ''gases'' as you allude to.
                      rings but had worn valve guides /stem seals, the blow
                      Regards,
                      the gorilla.
                      yeah no one is running that!!!
                      And if they were then they wouldn't have worn valve guides because if they were that smart to fit new rings in the first place they would have checked the guides!!!
                      Fuck me!
                        Get a room you two.
                        BTW in a quest to prove eachother wrong, one of you is contradicting what you wrote earlier- I will leave you guys to work out who
                          Can you pm a pic of your man veg to each other and be done :thumbs:
                            Man veg? A belter indeed, :hahaha: :hahaha: :hahaha:
                              :hahaha::hahaha:
                                Hi,
                                I do not believe I have contradicted myself
                                but if I have I apologize.
                                The reason why I got a little more 'excited'
                                than us Chilled Primates usually do was that
                                engine blow by can be caused for various
                                reasons. Its well documented.
                                While I enjoy good Technical debate as you
                                always learn something, hopefully, the introduction
                                of unrelated issues served no purpose and
                                one always wonders about the motive.
                                Regards,
                                The Gorilla.
