Originally posted by cantfind1
Yellow Oil Light
Filthy is an understatement Shane :bigcry: they were utterly cacked :bigcry:Originally posted by lawsy View PostIf in doubt, remove airbox and check dip stick. Takes 5 mins. Whilst your there clean out the intake trumpets. No 5 and 6 will be filthy. :thumbs:
All nice and clean now though.
Anyone done the above on the CSL?Originally posted by cantfind1 View PostGod knows why none of you have not fitted oil catch cans yet??
Get rid of that breather hose polluting your throttle bodies, ICV, air rail, trumpets and inside the airbox!
Looking at the state of the inside of the airbox it would be something worth considering i think.
God knows why none of you have not fitted oil catch cans yet??Originally posted by lawsy View PostIf in doubt, remove airbox and check dip stick. Takes 5 mins. Whilst your there clean out the intake trumpets. No 5 and 6 will be filthy. :thumbs:
Spot on :thumbs: :thumbs:
Think your right Shane, i'll pop the airbox tomorrow and check with the stick just to be sure :smokin:
or the oil level sensor itself crapping out as they do on all crappy BMW sensors ....
What was your last long term reading? Was there no indication the level was dropping? Was it filled up to max at the last oil change? I would put in 0.2l, drive it for a short distance to see if the problem (yellow light) reoccurs. I need to check the hand book, but I believe you can drive for a short distance before needing to top up so no damage should result. Instantaneous reading will then give you an idea if you are low or high
Yellow Oil Light
Had the yellow oil light pop up upon shut down of the engine yesterday.
Id just done a run of over 150 miles over some of scotlands best roads through the Grampian Mountains so plenty of elevation changes etc etc.
Has not happened since.
Just the up's and downs of the hills or low on oil???
Car historically doesnt use oil that much so was a little surprised as I had it changed only 1500miles ago.
Just a top up required??Tags: None
