New MOT problems
    New MOT problems
    Who knows about the new MOT regulatiosn and are they likely to cause us any problems with 100cell cats, replacement seats, no rear seats, coilovers etc etc
    Just wondering before mine goes in on 20th
    4.1.4 Compliance with requirements:
    (a) Lamp, emitted colour, position or intensity not in accordance with the requirements
    (b) Products on lens or light source which obviously reduce light intensity or change emitted colour
    (c) Light source and lamp not compatible
    4.1.5. Levelling devices (where mandatory):
    (a) Device not operating.
    (b) Manual device cannot be operated from driver’s seat.
    4.1.6 Headlamp cleaning device (where mandatory):
    For anyone with a remap, section 6.1.9 may be relevant.
    6.1.9 Engine performance:
    (a) Control unit illegal modified.
    (b) Illegal engine modification.
    There will also be a new check on the general condition of the wiring:
    4.11. Electrical wiring
    (a) Wiring insecure or not adequately secured.
    (b) Wiring deteriorated.
    (c) Damaged or deteriorated insulation
    and on the function of airbag and seat belt pre-tensioner systems:
    7.1.4. Safety belt Pre-tensioners:
    Pre-tensioner obviously missing or not suitable with the vehicle.
    7.1.5. Airbag:
    (a) Airbags obviously missing or not suitable with the vehicle.
    (b) Airbag obviously non-operative.
    7.1.6. SRS Systems:
    SRS MIL indicates any kind of failure of the system.
    So if your 100 cell CAT's or aftermarket seats are causing any warning lights lamps then yes, it will fail.
    IIRC there are a few other bits in there as well cars fitted from factory with CAT's must have CAT's, tyres pressure monitors must also be full operational.
      what about brake pad warning lamps/systems
        I was told any dash lights on is now a fail,its ok to have broken springs now though.:banghead:And the seats must be able to move backwards and forwards.
          Just found this.
          As of the 1 January 2012 the MoT Test will incorporate a malfunction Indicator Lamp (MIL) check. This will call for the examiner to visually check that warnings lights for ESP, SRS, ABS and TPMS are not permanently illuminated. This will come into effect from 1 January but will be highlighted as an advisory item only until 31 March. From 1 April onwards, vehicles will fail an MOT if these lights are illuminated. Warnings lights or MIL that are to be noted if illuminated include ESP; Electronic Stability Programme, SRS; Safety Restraint System, ABS; Anti-Locking Brake System, and TPMS (Tyre Pressure Monitoring System).
            What about airbag?
              Jeezus Shimmy! What about the cup holder?
                I wish I had one, would stop me spilling my skinny frappucino on the alacantra
                  What about airbag?
                  Will be a Fail.........
                  Do you need a friendly local tester..........
                  Althought, maybe I should ask how many lights are up on your dash first...............:whistle:
                    none :supz:
                    thinking more about the wifes SMAX
                      none :supz:
                      Just unplug it and stick in a resistor
                        Anyone with a cup holder in there CSL will defo fail and get a ban from here.:hahaha:
