Very slight play in steering wheel....
    What should I be checking first folks ?
    (and before the gags start, it was there prior to car limits !)
    Re-balance front wheels in my case one of my spacers was a bit warped must had been brett bounce added weight at silverstone
      By play to you mean it moves with out moving the wheels OR it wobbles when driving?
        You remembered to put the spacer on that time then.:hahaha::blalalala:
          yep - moves w/out moving the wheels very slightly...
            This ^^^^^^^^^^^^^
            If it wobbles when driving it could be balance out, ball joint, track rod end, or track rod.
            If the steering moves but the wheels don't, then most likely track rod end or track rod.
            But you need to get it jacked up and check for side to side play in the wheels.
            Ideally get it checked by a suitable person, not someone in a suit:hahaha:
              Shimmys gone to Google that now,then pretend he knows what he's talking about.:hahaha:
                See my post above.
                But you need to illiminate the steering collumn.
                How do you know the steering wheel moves without the wheels moving?
                You will always have slight play, is it engine on or off. Power steering systems always have slight play when engine not running, run engine and the play in the rack can disappear.
                As above though, better to be safe than sorry, get it checked out.
                  nice1 will be haunted by that one :hahaha:
                    This ^^^^^^^^^^^^^
                    Google says "you is fucked"
                      See my post above.
                      To be honest, I dont Shane...it just feels like they're not
                      Its minimal (maybe a 1 degree turn in either direction from cente) and when engine is on.
                      I'll be up to Elms in the next couple of weeks for MOT anyway so I'll ask Gareth to take a look.
                        Check he's not on holiday or ill before you leave.:hahaha:
                          You forgot to add or of ill :hahaha: Will have a look for you :beer:
                            :beer:
                            I'll call this week.
                              :beer:
                              This will make Bounce smile im off wednesday 1st Feb , but not happy day off as it for a funeral .
