Anybody try 285/35/19's on the rear?
    Hi guys...
    I just wanted to know if any of you have tried 285/35/19 Michelin Pilot Sports on the rear of your CSL's?? Are they any better or worse than the 265/35/19's....?
    Please let me know
    Thx!!
    I know GlenDoggy has the same width but not diameter....
    :beer:
      Originally posted by northernjim View Post
      I know GlenDoggy has....
      :beer:
      Doesn't G-Dog run 18" TD wheels with 285 35 18s at the rear :whistle:
        :hahaha: why does my brain retain only half the required information????
        don't even mention goldfishes:birdman:
          In technical terms that's more then half of the correct/required info :whistle:
          ... don't even mention goldfishes:birdman:
          Well, I wasn't about to insult the goldfishes :blalalala:
            BBS E88 :whistle:
              I assumed Matt meant
              Doesn't G-Dog run 18" TrackDay wheels with 285 35 18s at the rear :whistle:
              :smt039
              although why I am sticking up for him I've no idea:hahaha::bigcry:
                BBS E88 :whistle:
                you may as well post some pics up while you are here sailor:smokin:
                  285/35/19 will have around 40mm bigger diameter than 265/30/19 and 20mm bigger than 255/35/19 so it may well rub much easier.
                  If you want to run 285 tyres look out for 30 profile if I were you
                    Ok...thanks a mil for the info guys!
                      Ok...
                          but its much heavier then the 265/30/19 no?. And would the stock csl rim fit on the 285/30/19? would this have any advantage to change to 285? better grip i suppose or?
                            As far as I remember Loaded is running 295 in the rear but don't have info on rim offset. It was a dream to drive with 265 in the front and 295 in the back. With 265 in the rear it was quite tail happy :thumbs:
                              I'll piggy back on this thread for similar sort of inquiry.
                              Will 245/35/19 at the front and 275/30/19 at the rear cause any type of issue?
