rear wheels up fr
    rear wheels up fr
    Hi all im runing 19"CSL rears up fr i have 265 30 888s with standard shocks, turner top mounts set at -3 degrees camber been for a blast all seems good, as anyone run this set up before and if so had any problems I no Alex run rears up fr for a trackday at don park with no problems but think he had coilovers i use the car for ring trips only any advice well come thank Clayton
    Tankslapper is your man, he used to run that setup, surprised no rubbing though, would leave comments until you have gone down the foxhole at 130+ :hahaha:
      On full lock it rubs a bit but only ever on full lock in the rain sometimes with traction control switched off :thumbs: as you say the foxhole is the test for any set up as well as testing how big your balls are :hahaha::hahaha:
        i ran for one trackday
        you have to run -3 camber and you still get rubbing. hence why most run alternate rims to alter offset and avoid rubbing and -3 camber
