SMG II gear change problems
    Ok guys thought id post over here to see what you knowledgable peeps might think
    Long story short.
    I have a 2002 m3 Convert.
    88K
    I recently had the diff replaced as central bearing had issues and leaking seals too.
    At the time I had terrible judder
    and when they took out the clutch to replace it they found the clutch so badly worn that it was frayed at the edges
    New clutch fitted
    So work done.
    1. Diff fitted
    2. New clutch and flywheel
    3. SMG fluid replacement for new
    4. Diff oil - and friction modifer
    5. SMG adaptations
    6. New Salmon relay
    7. 2x ident springs replaced
    8. Pressure plate changed
    9. Rubber flex disc replaced
    10. Drivelogic left same as original settings
    11. Rolling paddle reset done
    Heres the problem
    On full power - that is gunning it between
    2nd into 3rd
    3rd to 4th
    I get a lag - the gear engages after a visible pause in power - and there is a sound from under the car - best described as a 'clacking' sound
    like if you beat two pieces of two by four wood planks
    There is a double 'clack' - and pause as car goes into gear between 2nd -3rd and 3rd - 4th.
    All other gears are perfect and no problems, sounds etc.
    Blipping on downshifts are fine
    Downshifting into 3rd or 4th - does have a delay and car does not select the lower gear until its happy in the problem gears only.
    In other gears the downshifting is fine...
    Can anyone throw any suggestions
    Someone mentioned to me syncromesh ?
    Any thoughts appreciated.
    Mo
    Also does this make sense
    When I had original juddering problem It started off between 2-3 3-4
    This got worse and it started happening in all gears so quickly realised that the clutch needed replacing
    However didn't get clutch replaced for about 2 months due to needing car as daily driver for work
    So did the car store in memory the readings or problems with these gears that it then carried over to the new clutch ?
      Was the cluch bite reset ?
      after the clutch was fitted
        Hi Mark
        Im not sure - ive asked the owner of the garage to confirm...
          I had familiar issues.
          Check output cylinder clutch Nr8 http://bmwfans.info/parts/catalog/E4...rol_m_gearbox/
          Mine , the plastic on edge was quite dissolved.
            Thank you so much for that link
            the car is due back in garage soon for them to check again
              Ive asked and the owner isnt sure it was done
              he used a specialist to come in to do the adaptations etc who has all the Gt1 kit etc..
              hes going to re-confirm
              thank you will get it checked when the car is in
                Bmw do this after they fit a new clutch to reset the bite
                they can also run a check on the gearbox.
                If i was you ask a bmw bealer for a price to run a check on the clutch and gearbox should only be about 1 hour labour :thumbs:
                  Garage has confirmed now that the was checked and the mine was pointed and in good condition
                    Thanks
                    I shall get the garage to do it as its still their problem for now
                    I trust the garage as the owner has become a mate through these problems.
                    He wants to get into doing proper servicing on M cars so treats this as a learning experience ...
                    If all things fail ill take it to another specialist who is very well respected.. but I wanted to exhaust the possibilites first ..
                    I will defo ask if clutch biting point was reset
                    but this strikes me as an obvious thing to do with a new clutch
                    and would get missed if someone forgot to only...
                      Hi,
                      Pure Guess on what your have descibed.
                      Your selectors in the Gearbox are worn,
                      and so when you engage, instead of the
                      detent Springs aligning for selection,
                      they are mis-aligning, solenoid actuators
                      clacking, so that there is
                      resistance at the selection take up.
                      Changing up under load, so I am guessing
                      that the 'clacking' noise is the selectors trying
                      to engage, actuators, hence why you have a delay in
                      Gear changes.
                      Changing down, the engine 'Brake' loads as you
                      change down which loads the drive train and hence
                      the selection process is again mis-aligned.
                      I would guess that if you drive hard, lift off,
                      so as to unload the drive train and select to
                      change up then it will be much smoother and
                      without hesitation as the 'selectors' are not
                      under load and so slide in easier.
                      Just my guess on what you have said.
                      Regards,
                      The Gorilla.
                        Originally posted by The Gorilla View Post
                        Hi,
                        Gear changes.
                        Regards,
                        The Gorilla.
                        Thanks Gorilla
                        That makes sense with how ive been driving while this is happening
                        Im in s3 mode all the time now
                        and as I go through the gears im always careful to change up between 2nd to 3rd below 3k revs or with foot off the pedal and not too fast ...
                        This works every time ...
                        However today I was caught in front of car up my a$$
                        and booted it a bit around the roundabout
                        of course 1-2nd fine but forgot about 3rd
                        clack clack - clack - clack -clack
                        I was on so many revs that this time the gear seelctor just flashed at me
                        i changed up to 4th to try and catch a higher ratio - still flashing
                        finally id slowed down by now enough that I reselected 2nd which engaged and then went up the gears smoothly
                        sheesh !
                        Is there anyway to service the 'selectors'?
                          Hi,
                          Find a replacement SMG Gearbox
                          in good condition with as low
                          mileage as poss, will be by far
                          the Cheapest option.
                          Regards,
                          The Gorilla.
                            Hi,
                            Regards,
                            The Gorilla.
                            :bigcry::bigcry::bigcry:
                              Hi,
                              Regards,
                              The Gorilla.
                              Will BMW or Getrag not sell parts separately or something?
