Advice on How to adjust Kw clubsport
    The current setting of my kw clubsport suspensions is definitely too hard and too low for road use and I would like to change the setting while driving on the road.
    The biggest problem is the height, too low for any speed bumps ( almost impossible to avoid touching the bump)
    As I bought the car recently, I have no experience in changing the setting (compression, rebound, height).
    How difficult is to change the setting? Can you work on them without lifting the car? Should I ask the assistance of a garage?
    Many thanks for you advice!
    For all those with KW Clubsport suspension kits fitted to their car, these are the recommended settings for compression and rebound direct from the KW factory in Germany. :smt023 There is a 'Basic' setting for road use, as well as 'Ring Dry' & 'Ring Wet' settings. Road Basic Setting Front Rebound 6 clicks Compression 1
    There are a few threads about heights with measurements
      If you were just changing he adjusters you could do it yourself
      If you want height changing then best get it set up by a knowledgable mechanic to well known settings
      Shimmy
