What would be considered too early? I know it's 1200 and people frown if they are late but what about early
Early running in service
The official BMW line with the running in service is that if its done more than 2000 miles before its running in service then the engine will not be warrantied now. And yes the BMW national database has records it based off service invoices and im told it flags up on their system if it was over 2000 miles.
Equinox
He was asking whats too early.Originally posted by Equinox View PostThe official BMW line with the running in service is that if its done more than 2000 miles before its running in service then the engine will not be warrantied now. And yes the BMW national database has records it based off service invoices and im told it flags up on their system if it was over 2000 miles.
Equinox
Just use the thing, drive it down to see me on a saturday. That will be a 200 ish mile trip if you go the long way round.
Ill run her in gently for you, if you like. Ill use it to and from work, low revs, near 30mpg and 300 miles a week.
Running it in on bricks is useless, it needs load, if you run it in like that, the rings wont bed in correctly.
BMW may let your car be 800 miles over,but I bet they won't let you be 800 miles under.Originally posted by Equinox View PostThe official BMW line with the runninglet you be in service is that if its done more than 2000 miles before its running in service then the engine will not be warrantied now. And yes the BMW national database has records it based off service invoices and im told it flags up on their system if it was over 2000 miles.
Equinox
Shimmy taking the piss, I just went with it. It's amazing how many miles you can do driving around locally, pervingRunning it in on bricks is useless, it needs load, if you run it in like that, the rings wont bed in correctly.
I've seen your local driving :hahaha:
I couldn't wait to send the car later too much on
Originally posted by s.mac View PostShimmy taking the piss, I just went with it. It's amazing how many miles you can do driving around locally, perving
did you get his name:hahaha:
Nice and easy on the commute, its saturday morning going to work that the legs get streched and I go the long way in. :finga:
:hahaha::hahaha:Quote:
