Suspension KW Variant 3
    Hello,
    I need some suggestion. I buy a KW Variant 3 for my CSL. Have you any setting to suggest. The use on track is mostly at the ring.
    What do you think if I don't put the rear sway bar? I will make a ring trip next week but the sway bar is to available.
    Thnaks in advance
    Sell it and buy Clubsport or Intrax1k2 :thumbs:
      Perfect I knew that I take a great decision :smt003
      :bigcry::bigcry:
        I thought Clubsport are to hard for a street use.... I am from Rome and the streets are like this
          Move to Germany:blalalala:
            :hahaha::hahaha::hahaha:
              ....... and a suggested set up to go to Germany??:-D
                Hi,
                Quote- ''..... and a suggested set up to go to Germany??
                Intrax 4 Way.
                Regards,
                The Gorilla
                  2 to 2.5 * camber front. 1mm toe out
                  1.0 * rear camber 0.5mm toe in
                  Dampers as you please
                  KW V3 does not come with topmounts, unless orederd seperate, so if you have standard top mounts you will only get 1.5 ish on front.
                    So advice so far:
                    Sell V3
                    Buy Clubsport
                    Sell house
                    Move to Germany
                    Fiddle with the set up!
                    :supz:
                      Thanks
                        So advice so far:
                        Sell V3
                        Buy Clubsport
                        Sell house
                        Move to Germany
                        :supz:
                        I put house and V3 on ebay. I wait a bid :-D
                          top man!
                          you know the formula, small house-big garage
