Thinking of running no rear ARB?
    Ok, seems strange but I am getting a knocking noise from my Rear ARB which is the Turner motorsport one with adjustable drop links.....
    The knocking is coming form the Bar hitting the two metal subframe mounts due to the car being low....about 638mm from ground to top of arch....
    On track the car is a bit tail happy....so I was thinking of removing the rear ARB all together solving both the knocking noise and softening up the rear somewhat to try and induce less oversteer....
    Any thoughts...or should I just do it and take a test drive....lol
    Why not just put CSL ARBs on?
      Im being serious here.
      Not taking the piss out of your tyre choice, but what tyres are you running now.
      What are your tyre pressures.
      What tyre size are you running
      What tyres have you used.
      What suspension are you running.
      Why are you running adjustable roll bar links.
      What geo
      What spring rates
      What damper settings.
        What geo
        What spring rates
        And what colour pants are you wearing!
          According to my calculations he's wearing yellow fronted brown backs...
            :smt043
              I'm not sure on the colour, as Im currently in my gimp mask. But they are crotchless, because my rear end is quite loose too:119:
                What geo
                What spring rates
                god, you can be so rude sometimes
                  hahahaahahahaaha:gayfight:
                    What geo
                    What spring rates
                    Lawsy stop trying to get my setup out of me! lol
                    Don t see what any of this has to do with knocking....also my rear end has always been loose in this car, with KW, Intrax and now Nitron...also with various tyres from road and track...
                    Adjustable droplinks are needed so as not to ruin the corner weight. So I cannot fit standard ARB's
                      Hi,
                      Turner sell 2 different sets of Adjustable
                      Rear ARB Drop links.
                      If you do not have their shorter version then
                      the rear ''knocks and bangs'' when
                      the car is lowered.
                      I run their shorter version which
                      are wound all the way in, with H/R rear bar
                      set to full soft and the car at the rear is
                      well planted and very predictable,
                      on Cups or Slicks.
                      Not sure I would want to run a preceived increase
                      in front spring / damper rate by removing the
                      rear bar in the dry, even though it works well
                      in the wet, ''Feds'' aside.
                      Regards,
                      The Gorilla.
                        I was more referring to the loose rear end than the knocking.
                        Genuine questions that the answers could help understand your rear end looseness.
                          Rumour has it if you want a stiff rear end Lawsy's your man :gayfight:
                            Your boyfriend has been pillow talking again.
