Something's broken
    Cheers for advice, all looks good on service front.
    Since inspection 1 in Nov 09, had oil service July 11, which means the Inspection 2 is due July 13, i was planning on having it April time anyway.
    Ill just ignore what the car is saying, it still reckons it has 13,000 to go till the inspection, unless the numbers are going to tumble quickly in the next 4 months.
    Ill keep Marks advice about asking about goodwill in mind, maybe i can strike a deal if i want an Inspection 2 doing at the same time...?
      Sorry to hear about the problem.
      I hope you sort it out quickly.
        It turned our to be the diff (Sh*t), but was the bolt that holds the diff to the subframe had come loose and then sheared off, wrecking the thread in the diff. Diff itself is in tact, but the noises were due to the diff actually moving around as the clutch engaged!
        After long conversation and options, Sytner, who are being really helpful are putting in a goodwill claim form, as the diff was replaced under warranty in 2008, 30k miles ago, so i reckon either the bolt wasnt fitted correctly or its simply failed. (everyone check their diff bolts)
        If the goodwill gets rejected im looking at a bill of over £2.5k! so if anyone has any advice or has experience and wouldnt be averse to a quick chat over the situation im in, it would be gratefully recieved!
        Should i ring Elms and see what they think?
          Can the casing be repaired/welded ? Or is it beyond repair? I'd go down that route if you end up having to pay out ! Fingers crossed
            Yes, i have the option of having the case re-helicoiled, but thought id attempt the correct resolution first. fingers crossed!
              I guess you are talking about the front bolt (?).
              BMW has new bolts for the diff cover (2 bolts).
              Here you can see the difference, the new bolt is not threaded all the way.
              The old bolts would break.
              You could look at a damaged E46 M3 diff and then swap the casing.
              It's not very difficult to do.
                Apparently, of the 3 bolts that hold it in, 2 at the back are ok, its the one 'at the side' that failed. And were threaded half way down, so the new style ones by the looks of it.
                BMW have since come back with “ due to the age were unable to offer any financial assistance towards the cost of this repair”
                  Sorry to hear that mate.
                  It's better if you find a damaged diff and you swap the cases.
                    Any pics of damage? Could helicoil. I have a kit here. They're in-expensive.
                    CSL Diff on eBay. Been up for a while and been reduced once before. Im sure he will take an offer. £300?
                      Diff bolts sheering was a very common problem on E36 M3's but ive never heard of it on an E46 before.
                        Im sure I have a casing here. If you are interested in the casing let me know.
                        Likely overtightened has caused it and stretched the bolt.
                          http://www.ebay.co.uk/itm/BMW-M3-CSL...item4ac15f5dac
                          That diff has been opened very recently, with no mention in the advert.
                          The bolts are like new and the rear casing is extremely clean.
                            I'm inclined to agree with lawsy (that's a first) the bolts have been overtightened, usually the sign of a pneumatic socket having been used to fit them and not a torque wrench.
                            There's a lesson to be learned there, just unfortunate that it's at your expense.
                              Thanks for the advice guys, hopefully some warnings for others as you say. Just a pity BMW don't want to play...maybe i should pick it up with them in Munich.....if i wasn't going to spend all my cash on getting this fixed.
                              Current plan is to use a local engineering firm to re-helicoil the diff casing mount (its only done 30k). If i can get a decent price on the labour as i also would like them to do an Insp 2, an exhaust hanger, check the subframe and do any repair/precaution on the back of what they find, hopefully what i have read regarding goodwill on the subframe will hold true.
                                It dont take too long to get diff out. Not a big job.
