Rear Seat Creaks / Rattles
    I've noticed since my subframe has been done that my rear seats are creaking like a bastid!
    Anyone got any good fixes for this?
    I might have to pull the whole rear interior out on the weekend (if the weather picks up), as it's starting to grate me now!
    It wasn't that creaky before it went in for subframe fix, so a bit weird.
    Any ideas?!
    Felt between the 2 60/40 rear sections. Mine used to do it too, shows how much the chassis flexes!
      Any ideas?!
      Mine is same since my subframe was done a couple of weeks ago.
      Its driving me fucking mad.
      I'll have a look at the weekend.
        Nath, dense question, between the split vertically in between the seats or across the plastic section at the back?
        That's exactly how I feel :119:
          Yeah, mine had some there from the off but squeek on mine was from that vertical split, from memory it wasn't sat right or had fallen off or something.
            Nice one i'll bear that in mind when it all comes out on the weekend!
              Same here :banghead: Infact, it's near on impossible to close or open the 60/40 rear seats individually since my subframe fix :smt017
                Ok lads mine was the same after some investigation her is the fix
                There is a bracket at the bottom of the 2 rear seats where they meet
                it is bolted to the floor with 4 12mm bolts they need adjusting first
                Put the 2 seat backs down and in the middle remove the T25 bolt then the cover over the seat fittings can be removed.
                Now remove the 2 seat backs they lift from the middle and they slide out at the other side its like a pin in a hole.
                Now loosen the 4 bolts but just enough that the can move now fit the small seat back in and move the bracket so the seat sits level at the to and tighten the bottom 2 bolts so it does not move.
                Now fit the other seat back and see how the gap is between the seats
                It should just have a small gap best to have the boot open to see this and they should be level across the top.
                Once you have done this and they are sitting nice remove the seat backs and tighten all the bolts.
                Now its the release part in the boot when the backs are up if they can move easy when pushed from the inside at the top they are not tight enough.
                pull the handle and drop the seat and under the rear deck where the back hits the top there are 2 bolts for each catch you have to loosen then just a little and move then towards the back of the car to make them tighter but not soo tight you have to pull the handle hard to open them.
                Hope this helps :thumbs:
                This is how the gap should look :supz:
                  Cheers Mark :beer:
                  I'll try this when my Cecil comes out of hibernation this weekend :thumbs: provided the pissing winter finally buggers off
                    Hope it helps its like the repair man just wants it out not giving a fuck as he is not in it :moan:
                      My back seats haven't creaked for 2 years
                        They wont creak in the garage shimmy :hahaha::hahaha::hahaha:
                          Thank God for this thread. I was convinced that there were additional creaks since my subframe was repaired, but figured that it was somehow down to the cold weather or that I was highly paranoid. Am now going to undertake the fix. Cheers. :beer:
                            Well I took out my rear seats to do the fix today...
                            As it was sunny I thought I would have a quick blat with the seats out...creaking was worse!! So took out the rear carbon panels and corner trims and went back out.
                            Creaking / rattling still there so I am completely stumped, its coming from the boot / rear quarter something is not right as the car was fine before I had the subframe fix.
                            Going to have to ring Elms tomorrow as something is clearly not right at all, am gutted as its ruined my weekend.
                              nice thanks for this i thought i was the lone creaker out there!
