Checked my dipstick and cleaned trumpets
  • alexk
    Guys the OEM filter can be cleaned too.
    Its a BMC race filter
  • sailorbaz
    I've had no issues mechanically or with any warranty work its had done. That being said, the only thing that's ever been done to the engine was the Vanos and was long before I changed to an after market filter however, it has been serviced twice with it fitted and never been mentioned to me.
    Good thing is, you can clean and oil it as many time as you want/need to for very little cost. Noise/performance wise I have to say, there is little to no difference. Maybe, just maybe a tiny wee bit more induction bark but that's about it.
  • deanobeano
    Thanks Baz - looks like a can get an ITG filter for £76 - seems like a good price when compared to OEM.
    Any issues in changing to a non std filter?
  • sailorbaz
    I done this to mine last time home also, while working in my passenger headlight washer jet it was easier to remove the air box for access and also clean the filter, trumpets etc.
    I bought an itg filter a few years ago, you can clean these yourself at home so I took to it for the first time with some degreaser and hot water. The colour of he water in the basin afterwards was unreal, it truly was filthy. Come up a great though and after drying out over night, was refitted as good as new. It cost me around £80 3 years ago, should have been cleaned long before now too.
    I usually find the hose at the bottom slips in easily enough, could just be my luck though.
  • digi
    BMW dealer close to you I guess. Should be about 80+ quid. Maybe pm mark, think he can help you.
  • deanobeano
    Where's the best place to order a filter from?
  • digi
    I thought mine was dirty. :-D
    The red plastic on the perimeter of my filter has split in multiple places so I ordered a new one. I think you need a new filter based on the photo.
    Maybe I was lucky, but I focus on getting the alignment on the rear section of the box, and the tubes just fell into place. I will need to take mine apart again as the dreaded PS high pressure hose has a slight leak and I need to replace it. Dun want my garage guy to scratch up my box so I told him I will remove it before I let his grubby hands fix the problem. Those PS hoses are frigging $$$. :moan:
    Good job on the trumpets, I think I will clean mine too. :thumbs:
  • deanobeano
    started a topic Checked my dipstick and cleaned trumpets
    Well the sun was shining and encouraged by all the good advice (and excellent vid) on checking the oil level, I thought I would give it a go.
    Stripping down was pretty easy. The Air filter was a lot more dirty than I expected. (My next service will be due by time summer 2014 - Insp 1). Tho I will probably change the air filter myself prior to this, depending on what your thoughts are here.
    The trumpets were grubby and 5 and 6 were grubbier still. I cleaned these up and also the airbox internals.
    The pollen filter box was also full of rubbish - grit, leaves and dust)
    Putting everything together, was more problematic. I struggled to get the bottom ram air connection to mate with the underside of the air box. You need fingers like ET to get down there!
    I managed eventually with some jiggling and a few pulls on my Vape ciggie.
    (Please tell me the way to do it - Mark doesn't show this bit on his vid).
    No warning lights on start up - took him out for a ragging to show him I was still the boss!
    I would recommend that all look to do this, if only to confirm oil levels but also to clean the internals of the airbox.
    No spanner found in mine by the way.
