After chatting o ONeill on Monday a Donny and taking a b,oddy god look at my Cups I have decided that I def need more negative camber, front and rear.
Whereas I used o wear my tyres out on the inside and outside, I think now with just that little more lean on the corners, the outer edges are getting much more action, increased roll, higher temps and more wear. Probably means that the temps across the tyre is uneven and loosing grip.
So, I'm thinking some more rent negative camber up to -3.5, and -2.25 rear.
ANY BODY GOT ANY REAR ARMS THAT CAN GET THIS CAMBER.
