AP calipers part number
    Hi, How can i find out what part number my AP calipers are to order some rs29 pads, they are 6 pot with 356 discs, I can get some pads that fit CP4070 calipers but dont know if they will fit :bigcry:
    I have 7040 on my focus - definitely not the right shape!
    you will have either 5555 ( 18mm pad depth) or 5575 ( 17mm pad depth )
    with new discs 5575 pads will def fit :beer:
    You need to order them from Martin on here trackm3
    best supplier I have found :beer::thumbs:
      did someone mention me :-D Thanks for the plug Jim
        Yours are 5575 Martin... but 5555 pads will should just about fit as those discs are worn...
          Great thanks will be in touch with martin soon :supz:
            :thumbs:
              The part number is written on the inside of the calliper facing the bell, visible just about through rims.
              Pagid pad shape E8018 will fit both CP5555 and CP5575, where as E1903 will only fit CP5555 and maybe CP5575 with worn discs (1mm thicker pads)
              Rears are pad shape E1265
                You Massive geek :supz:
                  so a visual inspection reveals that i have about 40% pad thickness on my Rs29. Is it ok for 1 more track day?
                    Yes should be fine.
                      thanks Martin. do you have rs29s for AP in stock?
                        Got about 10 sets of 8018 and 5 1265's so should be OK :thumbs:
                          you have email
