Intrax coilover knocking
    The rear is knocking like a b*tch, they were serviced 2k miles ago.
    When warmed up it gets better.
    Is this f*cked and unsafe to drive or does it have to be sent to intrax asap.
    Well p*ssed off!
    There is nothing wrong with your intrax mate, you just have to buy a real suspension, aka Ohlins.
    This will solve issues permanently.
      Well p*ssed off!
      Depends if it is knocking because a bolt is loose or because the damper is fucked LOL? If it's internal, then sounds like a seal has gone. However, it could be the rose jointed mounts? If not fitted with a rubber "sock", dirt gets into the ball and fucks it and then they rattle.
        Sounds like damper is fucked, checked all bolts but will take off later tonight.
        Cars been to Elms and had everything else checked.
          Send it off, from memory €90 each for a full rebuild plus parts and postage, 1 week turn around normally, Claudette is your contact over there
            Just been speaking to Claudette, looks like ill be doing Snetterton on Wednesday in my works van.
            Shame as she serviced them less than a year ago.
              You can borrow my standard rears if it helps?
                Mike thats awesome. Ill prat around with the car later. If you could bring them thats wicked!!
                Have you got a garage?
                  Not at home but at Snetterton. If not Bealo can you text James?
                  Billy
                    Sorry, I don't have one booked.
                    Remind me on Tuesday to bring them, as they are in my container at work .
                      Will do.
                      Billy
                        My intrax started knocking recently as well, did a trackday in it anyway. when I changed the wheels over at the end of the day, so the car is jacked up, you could move the wheel vertically with ease, damper had failed...
                        Intrax sorted it v quickly, they asked me to send both the rears to make them identical.
                        now I have a creaking front, bizarrely it doesn't do it in the rain
                        Anyway, good luck, I am sure intrax will sort you out.
                          Cheers Shoggy. my wheel has no movement but will check later.
                          Billy
                            Billy
                            I drove the car knocking from Paris to silverstone and back....may reassure you a little if you are still on the continent.
