Wheel studs and nuts instead of bolts
    Guys
    Who has got studs fitted and how much/how easy to fit?
    Any recommendations on types, colours and lengths?
    Can I do it myself and if so what is needed (glue?)
    12
    No, bolts for me.
    50.00%
    6
    Yes, I am a stud man
    50.00%
    6
    loctite 243
    I have 75mm front 90mm rear's but sizing depends on the spacers you use, even you could fit them shimmy:whistle:
      glendog has it!!
      shimmy,
      rob's the man to speak to
      wheel studs on his csl @ the ring:-D
        studs
        Dead easy to fit with a dab of locktight
        Makes life a lot easier changing wheels:thumbs:
          Had mine on a couple of years now:
          I fitted my BBS E88 track wheels today to see if there were any issues with widths or arch/suspension clearances, etc. I decided last year that i would change from wheel bolts to wheel studs/nuts for convenience so i fitted these first. It was a straight forward job and involved cleaning the hub threads prior to applying a
          Studs & nuts from Turner Motorsport in the USA.
          :-D
            I have 75mm Macht Schnell ones. I recommend to buy more Loctite as they are stingy with the one they provide in the kit. Piece of piss to fit, one of the best things I've done when it comes to changing wheels
