ABS Pump plumbing - Pic inside
    Hi all
    Can anyone help me decipher which pipe goes where on the ABS unit / pump?
    I think the thicker pipes that connect to OEM braided are not the lines that go to each corner (go to reservoir and servo)
    I basically need to know out of A,B,C & D - which corner of the car each one goes to.
    Can anyone help?
    My assumptions based on some research are
    A = Rear Right (driver)
    B = Rear Left (pass)
    C = Front Right (driver)
    D = Front Left (pass)
    Thanks
    No idea, but if you really wanted to find out just undo one line at the pump and then go to each caliper and push the piston back. when the fluid comes out you know which one goes where...
    Will prob take two if you to do it...also try not to get brake fluid on the car....for obvious reasons....
    Then you will need to rebleed whole system.....
    As I said...time consuming...
      Not listed in TIS?
        I think your assumptions are correct
        Just double check the abreviations on the pump block, but Im sure you are right.
        (VR - front right wheel)
        (VL - front left wheel)
        (HR - rear right wheel)
        (HL - rear left wheel)
