Will standard CSL brakes fit E46 325ci MSport?
    Does anyone know if I can fit standard CSL disc/calipers on my E46 325 vert (should i go for a bbk on the CSL)? The vert has standard 18" MV2 wheels.
    Any help appreciated.
    Yes the discs and calipers will fit ok :thumbs:
    BBK is a must if not for better braking for the looks :whistle:
      You sure?
        Hi,
        Quote- ''Does anyone know if I can fit standard CSL disc/calipers on my E46 325....
        If I remember correctly the caliper
        carrier has to be machined which is
        not good, and the 'X' clearance on the
        wheels will be the other issue.
        M3/CSL runs different hub flanges than
        325 etc.
        ['X' Clearance is rear of wheel spokes]
        Regards,
        The Gorilla.
          I stand corrected i know the do fit the m3 i thought they were the same :banghead:
            Think rear drum size for handbrake is different too
              Okee dokee guys, thanks for the info. Better to find out now!
