SMG Diagnostics and solutions
    Nz-m3
    If or when you re adapt the clutch bite point,clutch slip point,teach the gear change solenoid.if the pin was seized or the GPS sensors were weak a bmw diagnostic tool will or should pick this up and record it as a fault.i find that my car is smoother and feels better once i re adapt every 6 or so months.
    But saying what i have,the tool hasn't picked up a fault with any hydraulic or electrical component which is what leads me to believe its mechanical.my bmw tech and i have gone over these components on mine and found no faults with either!
    Re adapting the values will only fail IF you have a fault.if you don't have a fault it should adapt fine!
