Wheel speed sensor
    Originally posted by _Nathan_ View Post
    Cool, you running on my spare set at moment then?
    Can't wait to see what the 4 ways are like, gonna be difficult to know what has made the different though!
    No, Nigel stripped both front shocks, one had seized due to being parked up too long after rain I guess.
    You'll hate the 4 way until you manage to get it set up. Luckily you'll have help. Then it will be lovely
      Just copy the damper settings from the other car as a starter for 10.
      Deffo gonna use it soon! Get yer cheque book out and join me
        Forgot you had a mule car......
        Will need somebody else's chequebook at the mo
          Had a look at both sensors and NSF has a couplke of dodgy looking bits but seems ok really. Ill have to get both sensors monday and see if it cures it.
          Fluid is to the top still.
            call it Khama, but had this light come up today (just yellow brake light, this is image from google)
            Any guesses before I gets it fault code read on Monday?
            I think the bottom light is the hubba bubba warning light mate.
            Impacts forward visibility....hence warning.
            Fix is to lower drivers window and launch chewy out of car.
              Shimmy don't forget to leave ignition in second position and just wait 10-15 secs for the light to go out its self that resets the pad sensor wear indecators you might try that first if they have boon unplugged and not plugged back in properly
              That light usually indecates from pads are worn!!!
                Cheers, saw that on YT.
                I've taken off front wear sensor as even if not faulty, it looked a bit dodgy. I'll replace Tuesday and reset and see what's what. I'll buy the rear as el just incase.
                Not pad wear as they are not connected to the RS29
                  The ABS unit knows they are there without the wheels moving so no need to do this IME.
                  Running the MK60 ABS standalone now :thumbs:
                  Yes but if you have a faulty sensor and it causes the light to come on, if you fit a new sensor the light will usually not go out until either a, you erase the fault codes or b, drive the car.
                    I agree the light should go out after driving because it sees no fault!!
                      picked up a nice shiney new front sensor today from a friendly face and plan to fit it tomorrow morning and see if the fault goes away on the brakes
                      watch this space :smokin:
                        How did you find out which one to change :-D
                          I guessed looking at condition.
                          If it don't fix it, it's in stock and 3 minutes away.
                          Now go put out some fires!
                            Cheers Shimmy.
                            Will have look at mine this weekend see If I can do the same thing.
                            As for fires not seen one for three weeks, since another pub went up in smoke (Tumble dryer on standby over night).
                              Ok, front left changed, fault cleared in 22secs after ignition 2 turned on,
                              All sorted for about £8.
                              Cheers ears. :thumbs:
                                Cheers Shimmy.
                                Easy life
