Using a battery charger/conditioner
    My car hasn't been used in a month and now a dirty great skip in front of the garage means it's unlikely to move this month so I am going to get the new charger/conditioner out. I thought it was a simple case of connecting the crocodile clips to the terminals on the battery but my instructions say to disconnect the battery cables whilst charging. Is this correct or are they just being overly cautious ?
    What do you guys do?
    :beer:
    With the Ctek the connectors can be permanently attached to the battery and you just plug the Ctek in and leave it to charge for as LNG as you like. No disconnecting necessary.
      Ah I forgot to say mine is a Lidl special CTEK copy although German made and was well reviewed a couple of years ago when they were out. I can't see it would be any different though? it's got a facility to switch off so it can't overheat or overcharge.
        I use Black& Decker charger on all my cars which plugs in directly from the cig lighter. Easy to use and works very well for years.
          Do you bother to disconnect the battery leads whilst charging?
            If it doesn't switch off automatically then I can see why they recommend disconnecting it....should have got the real deal.
              As Shim says
              You need to connect the charger leads directly to the + and - terminals.
              As I recall their 5mm nuts and a washer screw onto the terminal blocks so no need to disconnect the main battery terminals. The insulated charger lead will now sit between the plastic battery cover and the hardboard boot floor covering towing eye and inflation kit.
              Mines an optimate 4 which is on from sept through to april. I never switch it off unless I'm unlocking the car for access.:-D
                I connect my CTEK MXS 5.0 in the engine bay :-D
                Simplessssss
                  Cheers all, I will fire up the lidl special tomorrow but now I will consider a ctek due to the known quality.
                  :beer:
                    Ctek MXS 5.0T to cigarette lighter.
                      Mine has a supplied two pin plug coming off the battery into the boot area just plug in and leave on all the time. :-D
                        It's probably just a bit of arse-covering by the manufacturer and it'll be fine if you connect it with the battery still on the car.
                        FWIW, I've got an Accumate charger which works fine, I often connect it to the jump-start points under the bonnet as I can't open the boot when the car's in the garage. I did have a CTEK that came with the car, but it died.
                          I bought the brand new ctek mxs 5 last night so I can hook it up without having to disconnect the terminals. £61 delivered for a quality piece of kit, I decided not to risk a LIDL £12.99 unit on my car
                            Good call :beer:
                              No, I don't. If I had to bother disconnecting them each time, battery would last much much longer anyway, hence losing the convenience of the charger.
