Hi,
Quote - '' If you're using the same feed as the OE item for your water cooled Mocal item, which as stated limits the amount of oil it allows to flow past it, then surely your cooling method will be no better than the OE air to air item, as the issue isn't actually airflow through the oil cooler, but the amount of oil it actually allows to pass through the oil cooler?
Is this some form of new English being used as a trial basis
or is this for real ?
You should stop making those assumptions MikeR
as I thought we had cleared that up many moons ago.
Do you know how a laminova Oil to water heat exchanger
works as reading the above statement it does not
appear so, no more than you know how my system is
fitted and works ?
So you do not have to make any further assumptions
Mike here is a link to a picture.
Now before the Oil stat is even open my Oil to water Heat
exchanger is working away as its feed via the top of the oil filter and
goes back to the Oil fitlre block on the return side
where the std oil cooler returns to.
I run JIc 10 lines for flow and return to the Laminova not Mocal
heat exchanger.
This is always full of oil so on start up there is
no pressuring required and as the engine has a
55 deg water stat fitted the water rad operates quicker and
thus assists in heating up the engine oil quicker as the
water from the rad return is what cools the Laminova
as it passes thru it..
So far so good.
Then on Track when my oil hits 95 deg Guess what the Oil
stat opens ,you know the thing that you keep wanting to remove,
and I now have a Oil to Water heat exchanger working
to try and keep temps even, and as the oil temp
has moved up above 95 deg my oil stat opens, yes that
thing you want to bin, and the std Air to Oil cooler then
also comes into play at the same time'' as its also installed on JIc 10
lines and fitted via a 'Y' with non return valve into the
=oil return feed, and guess what that little bit
of free ambient air just nudges the temps back down
below 95, the oil stat shuts, but only if you still have one,
and the oil and water temps then behave themselves again
all being kept as constant as possible by the oil to water heat exchanger
until the next little rise in oil temp, mostly on the parts
where I get all carried away trying to be Hans Stuck.
As I said there is no free lunch.
So please no more Assumptions or Trial English.
Regards,
The Gorilla.
fitted and works ?
heat exchanger.
So far so good.
Regards,
The Gorilla.
