anyone else have this? Took the CSL for an MOT yesterday - had a good 20mins drive before, so was up to temperature etc. The engine is hunting on idle - it's always done this since i've had it and Gareth did something to it last year (reset something?) but it's still doing it. It had an inspection 2 at BMW approx 1500-2000 miles ago (May 2012) so needs an oil service in a couple of months. Would like to get this sorted at next service. Any clues as to what could be causing it?
engine 'hunting' on idle
There are a few pipes that connect into the bottom of the airbox, it's certainly worth checking if one of those has come loose.
It sounds like it may be an air leak, worth having a spray round the intake system with a can of brake cleaner, see if the engine runs differently. Obviously dont spray the cleaner anywhere near the actual intake, or that will make it run differently!
), so i'll probably leave it till it's oil service. Good to have some insight into what it might be though.
