Anybody running Apex Arc-8
    Originally posted by Mike R View Post
    Around £1000 after all the import duty and VAT has been paid.
    Originally posted by Steve B View Post
    Plus 10% import duty and 20% VAT..... if you get caught out. I bought a Autronic SM4 ECU (£1000) from California and got it through without any taxes
    Many thanks guys!!!
      As I said: "£759.51 + Shipping + Duty, which is comparable with purchasing a set of used CSL wheels off ebay" (a set was recently sold for £1,225 with Cups fitted)
      So anywhere this side of 1K your quids in! :-D
      Little boxes aren't worth the paperwork, but with a set of wheels they will be all over it like a rash.
        How would it work if I got them posted to a relative in America, and then they posted it to me as a gift?
          Graham don't even think about it Wedding Bells ??????:finga::finga:
            I don't think you would get away with it, but you might get lucky.
              I'm running et35 9.5 front. It's perfect. So et 25 on 10j will be far out past front arch.
              It should be fine in rear, perfect in fact :thumbs:
              Depends on camber, 10 et25 are fine on mine, did buy a set of et15 but they didn't work!
                Yours doesn't move though does it. It's no good saying its fine when stationary :blalalala:
                  Out of interest what's the widest tyre and wheel combo that works on the front end?
                  What tyre size was on the 10" rim Nathan ?
                    Ouch.
                    :thumbs:
                    If its not trailered or swapped at track I wouldn't go above 9.5j and 265
                    I think if you can run all the time on -3 to -4 camber, bigger is possible
                      Ouch.
                      :thumbs:
                      Any more than 3* on road and it's bye bye tyres.
                      2.5* seemed to wear even on mine.
                        Yep.
                        Could cart around 2 in the boot and swap when you increase camber
                          Got 2 sets coming over for that group buy postage is about $500 for the 2 sets going with 10" on the rear and 9.5 front et22 the most aggressive yep will need to run camber at 3 but that's about where it is now.
                            Mine will be running 245 front and 265 rear.
                              Harsh but fair
                              250/640/18 all round
                                Lots of different setup options here if you can be bothered to trawl through 100 pages!
