Anybody running Apex Arc-8
    I'm running et35 9.5 front. It's perfect. So et 25 on 10j will be far out past front arch.
    It should be fine in rear, perfect in fact :thumbs:
    Yeah I've trial fitted a 10J ET25 and its tight but doable with added camber. I run 9.5J ET25 which is fine.
      On what camber?
        On what camber?
        I run circa neg 2.5
          Lawsy - what suspension is your car running? I'm fine tuning wheel fitment right now with KW Clubsport and Apex EC-7 9.5 / ET35.
            Originally posted by race.it View Post
            Got 2 sets coming over for that group buy postage is about $500 for the 2 sets going with 10" on the rear and 9.5 front et22 the most aggressive yep will need to run camber at 3 but that's about where it is now.
            you will probably need to run more camber than that to clear without rubbing!!!
            just fitted a set of these in 18x9.5 ET35 with a 5mm front and 10mm rear spacer, just clears nicely up front with -3 camber with a 265/35 tyre (i run -3 for road use and -3.5 for track use)
            very very light wheel, much prefer the look to the TD pro race i used to run
              I run 9.5 x 18 up front with et37 and 3mm spacer and I can run any camber so you must be close to being clear
